"Ice in the tray". Do you mean ice is in the well of the ice maker, or in the tray or bucket that collects the harvested cubes from the ice maker? If the problem is the ice is in the ice maker well, and will not dump, then, if the ice maker is turned on, and the temperature in the freezer is 14 degrees or colder then the ice maker has failed. In rare occasions an ice maker can be repaired but is rarely done, and is a repair only someone with strong working knowledge of ice makers can perform. If you are handy with tools you can remove the icemaker. 3 screws and power plug. Once out you can check the well to see if something has jammed up the rake, but that's about all.
Was this helpful?
Yes
No
Popular Solutions for Maytag MSD2454G Side by Side
my maytag refrig/freezer side by side started leaking water from the inside and now does not make...
(More)
my maytag refrig/freezer side by side started leaking water from the inside and now does not make ice
I have been noticing water leaking from under my fridge. I just now saw in the back of my freezer...
(More)
I have been noticing water leaking from under my fridge. I just now saw in the back of my freezer some type of coil or element red hot like the element in the stove. And the water was running down from the back of my freezer, to the front of the fridge and leaking on the floor. It happens every few hours. What should I look to replace of repair? Model # is MSD2756GE
(More)
