belt, etc. is not available from the rear!!! open the dryer door and look up at the underside of the recess the door closes into and remove the 2 phillips head screws there. then lift the front of the top a little and look along the sides to notice the metal slotted retainers for the top, the slide it forward a little as you lift is slightly.. once u get the lid loose from its retainers and lifted some it will need to be slid (i believe) to the right to disengage it from the locking tabs on the control panel. you should be able to look at the slotted tabs on the console to see which way it needs to go.. once you get the top off you should be able to look at the inside top corners of the front sheet metal face and see several 5/16th screws that once removed will allow the front to be removed.. hope this helps, best of luck, ttfn
Was this helpful?
Yes
No
Popular Solutions for GE DBSR453EBWW / DBSR453EBCC
The upper plastic trim piece that goes around the drum inside the door (drum bearing?) on my on my...
(More)
The upper plastic trim piece that goes around the drum inside the door (drum bearing?) on my on my GE DBSR453EB2WW dryer is broken. How do I begin to disassemble the sides/top to get at this? Where do I start?
GE dryer DBSR453EB2WW Timer doesn't work. Dryer functions , but timer doesn't shut-down as should if...
(More)
GE dryer DBSR453EB2WW Timer doesn't work. Dryer functions , but timer doesn't shut-down as should if set at dial. Removed timer , applied power and observed plastic gear move slowly. What else can I try?
The knob seems striped will not turn and pliers will not turn it. The dryer was running perfect...
(More)
The knob seems striped will not turn and pliers will not turn it. The dryer was running perfect until yesterday. It is a G.E. But I cannot find a model # this is just a guess.
