Question about Compaq Presario M2000 Notebook
Cpu colling fan
Cpu cooling fan not working, need to remove bottom part to access cpu fan. Unable to figure out how to remove bottom. Any help will be of great assistance.
please email me:
gold220@optonline.net
You also need a knife to place between the bottom bezel near where the power supply goes to unsnap the bezel. also you need to remove the gray bezel on top of the keyboard to remove the keyboard and the screws underneath...
Posted on Jan 13, 2008
    Problem Solver:
  • 27 Answers
If you look at the bottom and you will see a grill for the fan..Remove any screws that are nearest to this they will be flush to the bottom not on the sides..when cover is removed carefully remove screws for the fan (be careful as this will probably expose the cpu).Hope this helps
Posted on Jan 02, 2008
    President:
  • 4,402 Answers
There is usually screws under the rubber foot pads.
Hi there is a toolbar coming up the whole time saying,,,,,WARNING a problem with the cooling system has been detected, please turn of the computer and return for service immediately
Try to fix the problem without taking the laptop apart first but I would recommend using a powerful air compressor instead of a vacuum cleaner.
Welcome to FixYa! Based on the error you have received, this means that the cooling fan of your laptop needs to be cleaned and checked at. This is a common problem with any toshiba laptop. I suggest checking the heatsink of your laptop. If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It's nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
  5. If your laptop is still under warranty, you can take it to any Toshiba Authorize Service Provider and fix the problem at no charge to you.
Hope this helps! Thank you for using FixYa!
Jul 27, 2011 | Toshiba Satellite 1715XCDS Cooling Fan...
Tip
The MOST common problem with laptop (CPU) over-heating is caused by DUST/LINT...
That would be normal, as the variable speed fan comes on only when the computer is under load.
What is not normal is that the fan is not coming on when the computer overheats.Or that the fan is not cooling enough when computer is overheating.
Monitor computer temperature using a software, check if Fan is coming up when temperature gets critical.
If fan comes up but does not cool enough, then replace the fan, it is not efficient anymore because of a bad bearing or dust. ~Also ensure that fan is well mounted, if fan has poor contact with CPU surface , cooling will be poor.
If fan does not come up, and critical temp is not detected, then the sensor on motherboard is bad, this is very uncommon. When this happens the problem is usually related to system or power settiings , rather than overheating.
If fan does not come up and temp is critical, then fan is faulty, replace it.
There are also more than one fan on many laptops, check that one of the fans (CPU fan, video fan) is not completely ded, and therefore cause for the problem.
By using the software below you can also find out if the problem is really overheating. If temperature results within normal range, then usually it is not overheating.In that case test systtem and check power saving settings.
Here is the software to control your fan and temp. sensor state:
Download SpeedFan - Access temperature sensor in your computer
Download SpeedFan 4.38
SpeedFan - Free software download
on Jun 04, 2009 | Acer Aspire One Netbook 8.9" Notebook
My dell inspiron 1525 keeps turning off and shutting down without me doing anything. why?
The computer has a cpu fan that can get dirty over time. It's job is to keep the cpu cool. When the cpu overheats, the computer senses it and shuts it down immediately, to prevent permanent damage to the cpu. You can clean it by blowing compressed air into it, and should do that every few months, as routine maintenance. This is the most common thing that shuts a laptop down, other problems involve repair, so try this first. I bough a $7 three inch fan at Walmart to help cool the laptop, and when I run it, I never have it shut down on me, but once in awhile it will without the fan, especially when I play dvds or videos, which really work th' heck out of the cpu. There are also commercial laptop cooling devices, but my little fan works just fine. Hope this helps.
Mar 29, 2010 | Dell Inspiron 1525 Notebook
Compaq presario cpu cooling fan will not start spinning unless "helped" with tip of pen to spin over.If I dont start it manually,I get No cpu fan message,and shut down.I just replaced fan,as old had broken...
If the CPU fan speed is too slow or not working at all, the computer will shut itself off automatically to prevent damage to CPU from overheating. You may end up having to throw more money at the problem and get a new fan. I went to Compaq's web site, looked up your particualr computer, found out what type of fan you needed, and I did some research. I recommend getting the fan in the following link. It's very cheap, and has good reviews. The other fans on the site all have bad reviews. Hope this helps.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835114011
Jan 12, 2010 | Compaq Presario Cooling Fan CPU Heatsink &...
Proliant ML370T02 boot problem
Sounds like the CPU fan has gone bad and needs to be replaced
Sep 24, 2009 | Compaq (173907001) for ProLiant DL380 /...
Dell 5160 stop all of sudden. Message shows CPU too hot. What should I do?
There are 3 or 4 possible causes:
The fan in the computer is damaged.
You are using the computer on a very hot environment.
or ventilation outlets in the computer are blocked.
Aug 28, 2009 | Dell Heatsink Assembly
Unable to access my mail
check in your cookies you mite have disabled it and even there is virus in your system use some good anti virus to delete those
Jul 28, 2009 | Dell (H5195) Laptop Cooler, CPU Fan,...
Socket 478 3 GHz Intel CPU overheating
Simply open/unlock the clips and pull the heatsink off. Then you will need to remove the termal compound from both on top of the CPU and from the bottom of the heatsink. Papertowel + rubbing alcohol works well. Then you will need to re-apply thermal compound before reseating the heatsink/fan.
Jun 14, 2009 | Intel Socket 478 CPU COLLING FAN & HEAT...
Replacing cooling fan in ACER ASPIRE 3620 Notebook
Try this link:
http://www.insidemylaptop.com/clean-cooling-module-acer-aspire-3620/
Apr 17, 2009 | Acer Computers & Internet
My cooling fan on my mother board start making noise now as soon as you power up the pc it shuts down could it over heat that quickly or did it ruin mother board?
It is possible to burn out a processor in a matter of seconds without cooling. Please do not attempt to restart the unit, until you replace the colling fan on the processor. If it's not the processor fan/heatsink, you may have lucked out, but don't restart it till you replace the fans.The fan that sits on your cpu is the main concern, if it's one of the others the board should shut down automatically in order to stop this scenario from occuring.
Mar 09, 2009 | Computers & Internet
Compaq Presario M2000 Notebook Logo
99 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
