Question about Kodak EasyShare Z740 Digital Camera
Computer will not recognize my camera
I have had this camera for several years and have never had this problem. My computer will not recognize my camera is there. In my digital camera settings in my computer, I can not find Kodak Z740. It has only DC240-DC50. I can not find my cameral. I do not know what is going on. Please help.
  • Liffy Jun 17, 2008
    Computer will not read SD Impact 1GB Card. I get message "Failed to locate supported file types"? How do I correct this?
  • Anonymous Oct 23, 2008
    i have the same problem with my Z650 which always worked- now suddenly my computer does not recognize it and it doe snot show in the computer under devices....The computer is a Sony Vaio...
    Sergeant:
    Champion:
  • 310 Answers
Ok this is wierd DC240 is a camera made by kodak, DC50 is a camera made by canon. Now go to your device manager and see if its there with your camera still pluged in and uninstall it. Reboot compouter and see if it sees it as it really is. you might have to reinstall the soft ware again. Go to kodak and install it from there and then update it. hope I could help
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Posted on Jan 09, 2008
  • JP Services
    JP Services Jan 09, 2008
    The computer may be set up incorrectly. Do the following to resolve this problem:
    1. Select Start > Settings > Control Panel > System.
    2. Select the Hardware tab, then click Device Manager.
    3. Double-click Universal Serial Bus controllers.
    4. Right-click USB Root Hub, then select Properties.
    5. Select the Power Management tab.
    6. Clear the Allow the computer to turn off this device to save power check box, then click OK.
    7. Close all open windows.
    8. Restart the computer.
My computer will not recognize the cametra as a device. I have been using this device for several years without any problem.
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Sep 05, 2010 | Samsung Digimax D53 Digital Camera
I am trying to download pics from my Nikon coolpx to my IMac but iphoto does not recognize the camera - what do I need to do?
First, make sure that the Computer recognizes the Camera when connected to it using the USB cable.
When the computer recognizes the connected camera then a "No name" drive appears on the Desktop of the computer.
If the Computer is recognizing the Camera but iPhoto then follow the steps given below to transfer images from the Camera to the Computer:
Double-click the "No name" removable drive on the Desktop to view and navigate through the folders and files on the Camera.
You can see several folders, you may either navigate through each folder to locate the folder that contains the pictures or double click the "DCIM" folder to view all the images.
Next, copy all the desired images then paste them on the Hard Drive of the Computer.
Sep 15, 2009 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Canon Not recongized by Computer
Try to change the USB connection type in the camera menu. There are several types like Mass storage, Pict. bridge, and the one you need is most likely PTP. Anyway, try all of those and maybe it will work. That is the most common problem when connecting cameras to Vista based systems.
Sep 14, 2008 | Canon PowerShot SD1000 Digital Camera
Computer not recognizing camera
search your camera for the option of changing between PTP mode and Mass Storage mode
Jul 31, 2008 | Nikon D40x Digital Camera
Computer will not recognize video camera
How are you connecting to the computer? If using USB, how many ports on your computer and are they USB 2.0? Do you have any usb powered ports?
May 03, 2008 | Dell Dimension 4600 PC Desktop
Camera No Longer Being Recognized
Does it connect to the PC via a USB cable? Then try connecting to a different USB port or if you have try a new USB cable. I had the same problem with my IXUS 400 and changing to a new USB port, directly to the PC - not a USB hub, it worked. However now I have several issues with my camera - no sound or image on the LCD screen, but I think these are unrelated.
Jan 27, 2008 | Canon PowerShot S400 / IXUS 400 Digital...
Camera undetected by computer
Although I haven't had this issue with my S2 IS specifically, I have with 2 other digital cameras. The solution in both cases was to power the camera on BEFORE plugging in the USB cable.
In other words - Plug the computer end of the USB cable into the computer, do not plug the camera end in. Power up the camera in "picture view" mode, THEN plug the USB cable into the camera.
Not sure about Vista, but with XP, you should hear the familiar "Dong-ding" as the system recognizes the camera.
Nov 30, 2007 | Canon PowerShot S2 IS Digital Camera
Computer suddenly does not recognize my sony cybershots
I would buy a memory card reader (docking station) for your memory card. This is preferred over going through the camera, anyway. Beyond that, you say you have ruled out every other thing I could suggest. Are you sure about all those? Can you try this on another PC or does anyone you know have a card reader you could try the memory in?
Nov 29, 2007 | Sony Cyber-shot DSC-W30 Digital Camera
MAC is not Recognizing the S410
check the connecting cable or try another cable
Oct 10, 2007 | Canon PowerShot S410 / IXUS 430 Digital...
Kodak EasyShare Z740 Digital Camera Logo
99 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
