Question about Sceptre 17" LCD Monitor
Monitor turns on then off 3 seconds later
Hi i have a sceptre X7G-NagaVI lcd monitor some reason it keeps shutting off after i turn it on about 3 seconds its off again please help.
claudie
  • 3 more comments
  • Anonymous Mar 17, 2008
    yep turns on then 2 seconds later i get a black screen but the power led stay blue .
  • Anonymous Jul 19, 2008
    same problem, they need to do something about this
  • ctratovarius Oct 08, 2008
    when i start my computer, i have to click the monitors on and off button till the screen stays on ....otherwise the monitor will only click on for about a second .
  • mbandfield Mar 02, 2009
    I have the same problem and have read that I need to replace a capacitor on my power inverter board. I just don't know which one.
    I've removed the circuit board that the power cord plugs into (power inverter?) and I see several doodads that could be capacitors. I think that with help I'm capable of replacing the problem component. Can someone just upload a picture of where it is? Or email it to mbandfield@hotmail. Thanks.
  • Anonymous Apr 25, 2009
    Same thing but with a mag innovision
It's your inverter.
Posted on Oct 03, 2008
I have a Sceptre X7G-Naga VI 17 inch LCD Monitor When I turn the monitor on and boot the computer I get the red light for a sec then the blue light comes on I will also see windows booting up but the...
try with restarting computer & press F8 at the same time. u will see a menu where choose "safe mode" & start the computer. in safe mode see the display properties, set the refresh rate & resolution according to monitors specifications, apply & restart again. if that does not work, replace the main board of lcd monitor.
Aug 25, 2011 | Sceptre 17" LCD Monitor
Order of the connectors on the X7G-NAGAVI?
OK, you will have four connectors (each one with pink and white wires), there are two set of the connectors, two are above the transformer, two below the transformer. The monitor uses four lamps, two for the top side of the screen, two for the bottom side of h screen. You can plug either one of the pair of the connector to the top group of the connector, same for the bottom group of the connectors.
http://s807.photobucket.com/albums/yy352/budm/Sceptre%20X7G/
May 05, 2010 | Sceptre 17" LCD Monitor
X7G shows video for 1 second then goes black, any replacement boards available?
Hate to tell you that replacing parts on a monitor would be very hard not only to find the parts but it would be very costly, I would recommend scrapping it and buy a 90$ refab off tiger direct or something, the only thing you can really fix on a monitor is perhaps a dead pixel, other than that its not worth it.
Mar 21, 2010 | Sceptre X7G-Naga 17" LCD Monitor
My Scepter LCD Monitor just blinks when it's turned on
Open it up and the first place to look will be the power supply section, look for bad caps with bulging top/bottomseal, post back what you see so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 12, 2010 | Sceptre X7G-Agama II (Black) 17 in. Flat...
At start-up, Sceptre X7 monitor flashes on, then goes black. Must turn computer on and off numerous time before monitor will stay on. How can this be fixed?
Hi Friend,
You need to check your display setting in your computer..i mean to say..you need to click on desktop then properties then display then screen saver then change the time.....
Dec 20, 2009 | Sceptre X7G-Naga 17" LCD Monitor
Sceptre X7G-Naga VI
My problem sounds equivelant: The problem is that it will power down after 15 minutes, then take 1/2 hour or more to power back up!I believe I have solved my problem with my X7G! I remember seeing a direction on the only direction papaer I got with it that told me to Turn off ALL POWER SAVING WINDOWS SETTINGS! I think the monitor is set to care for all the monitor/power saving itself. I am going to try it and will get back to you, or just try it yourselfs!
CWD
Dec 22, 2008 | Sceptre 17" LCD Monitor
Sceptre monitor x7g-nagaVI
Problem is 2 Capacitors on the power inverter board, at 1000 uf 16 volt. This one was on the model xg7-naga V 17 inch monitor.
Jan 14, 2008 | Sceptre 17" LCD Monitor
LCD Monitors x7g troubleshooting
Check some of the other posts as it is probably just a bad capacitor or two and very easy to fix if you can do that sort of thing. I did and mine is back up and running.
Jan 05, 2008 | Sceptre 17" LCD Monitor
Sceptre X7G nagaVI problem
For most of the problems above you will find it is bad capacitors on the power board sending unstable power accross to the controller board.
For the last posted problem (Comment by Guest, posted on Jan 02, 2008) you have a dodgy inverter circuit that needs to be repaired.
Both faults should be fairly cheap to have taken care of at your local TV repair shop. You may need to call a few in your area not just for a quote, but also to see if they are willing to work on an LCD monitor.
Hope that helps you all =)
Dec 21, 2007 | Sceptre X7GNAGAV 17" LCD Monitor
Sceptre X7g Monitor Flashing Red & Blue Lights. Blank Screen
i fixed this problem by unplugging the monitor, unplugging the video cables. Then hold down the power button while plugging it back in. Release power button and then press power button for on. It worked then. I got the icon for no signal, i plugged back in my monitors. Sceptre X9W
Sep 11, 2007 | Sceptre X7GNAGAV 17" LCD Monitor
Sceptre 17" LCD Monitor Logo
663 people viewed this question
Top Sceptre Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
methjd
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
