1991 Peugeot 405 Logo
Posted on Oct 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Peugeot Expert Van Cambelt change
Peugeot Expert Van had its cam belt changed at 66,000, it is now on 113,000 and is 5 years 1 month since the belt was changed, when does the belt need changing again?
Anonymous
Level 2:
  • Expert 301 Answers
  • Posted on Oct 28, 2009
Anonymous
Expert
Level 2:
Answers
301
Questions
0
Helped
174970
Points
959
Most cam belts need to be changed every 60,000 miles. I would change again somewhere around 126,000.
1helpful
2005 peugeot 206 GTI 180 cambelt changed at 82,000kms water pump now leaking advised to change cambelt at same time as replacing water pump odometer is now at 92,000 kms. What do you think?
when replacing the pump if the timing belt has to be removed , it is not necessary to replace the belt PROVIDING THAT THE FOLLOWING PROCEDURE IS FOLLOWED
before removing the belt mark it with an arrow indication direction of movement replace the belt with the arrow correctly position as before removal
timing belts ( for want of a better description) breakin from running in a set direction
if replaced running in the reverse direction then the "breakin" gets far worse and early belt failure occurs
when the belt was replaced , if the cam seals , crank seals idler and hydraulic adjuster were not replaced then it might be worthwhile to have it done with the water pump as oil on a belt reduces the life to about 1/2
1helpful
Orange engine light on Peugeot 106 independence, car sounding chuggy, just had cambelt done also
most european cars only give colored lights when maintenance is due or a malfunction is detected. since the car is running "sluggish", may want to get a fualt code pulled from the ECM to help find the problem.
1helpful
I have a Citroen Diesel ZX19 Turbo. It is Very hard to start when cold and takes a two or three goes to start when hot.I have replaced Glow plugs with Bosch ones from a Citroen dealer only a month ago plus...
Did the poor starting coincide with the cambelt change ,as it sounds like you may have a camshaft/fuel pump timing issue.If the pump/camshaft/crankshaft are not locked in place when you change the belt they can easily move a tooth or two.If the problem didnt coincide with the belt change then it might be a fuel problem.
1helpful
2answers
I have a 206 peugot 10 years old, i have been strongly adviced to change fan belt when mileage hits to 70 000, so i was just wandering how much and is it really worth it?
you mean the timing belt i presume ,ten years old low mileage but its the age ,the belt may be ok but take the top part of the cover off and look at the belt ,if you can the shape of the teeth showing on the back of the belt then change it as they only cost 16euros for the petrol engine and they are very easy to change done one yesterday andf it took me all of 20mins .
1helpful
2answers
1helpful
How many miles be change cambelt on peugeot 307 on a 51 plate
you should change the timing belt at 60,000 miles or every four years (which ever comes first) this is because the belt will deteriorate due to stress,temperature,ect. replace the belt tensioner while tou are there..
Frequency of cambelt change for a peugeot 306
Every 80000km or 4 years. 1km=0.625 mile
4helpful
Instruction to change cam belt on peugeot 307
If its DIY job then you can download the instructions i have uploaded for you (available for 45 days to download from today).
First of all you need to take off ancillary drive belt.
http://www.gigasize.com/get.php?d=ml20tdk87lf
then follow the instructions to change Cambelt.
http://www.gigasize.com/get.php?d=mb7lpdd4ctc
It is better if you change the tensioner roller and water pump when you change the cambelt as they are running under same belt and suffering the wear & tear as well.
18helpful
2answers
"when do i change the cam belt on a peugeot 307 sw diesel"
usually you should do it for peugeot diesel at 122000 miles along with water pump and the tensioner roller that runs under the cambelt too. But to be on the safe side do it at 100000 and save the fortune.
It took me (DIY job) about 6-8 hours as i wanted to save 450 pounds.
Cambelt change
i believe it to be 50,000 miles or five years....if your not sure change it its cheaper than an engine repair!!
Top Peugeot Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Arnie Burke
Arnie Burke
Are you a Peugeot Expert? Answer questions, earn points and help others
