I have a "philips magnavox" "27" tube tv" Model# CS2744 C106.
It won't turn on. 5 yrs old. Some time when I try to turn on, "on light" comes and goes.
Thanks for your help.I have a "philips magnavox" "27" tube tv" Model# CS2744 C106.
GE 13TVR40...No lights, no sign of life. Worked up until a few months ago. I opened back, found 123V AC ok to circuit board, also found 2 small fuses...both check ok with ohmeter after I removed them. Any suggestions? Thank youGE 13TVR40...No lights, no sign of life. Worked up until a few months ago. I opened back, found 123V AC ok to circuit board, also found 2 small fuses...both check ok with ohmeter after I removed them. Any suggestions? Thank you
GE 13tvr40. No power, no lights. OK couple months ago. I found 123V AC inside on circuit board. Found 2 small fuses...both ok on my ohmeter (after pulling fuses out). Any suggestions?GE 13tvr40. No power, no lights. OK couple months ago. I found 123V AC inside on circuit board. Found 2 small fuses...both ok on my ohmeter (after pulling fuses out). Any suggestions?
AnonymousApr 21, 2008
I have a five year sony 34xbr800 that will not turn on with remote or button. Is it worth repairing and how much is reasonable?I have a five year sony 34xbr800 that will not turn on with remote or button. Is it worth repairing and how much is reasonable?
You can't post conmments that contain an email address.
For a possible fix to your Sony KV-34XBR800, go here http://www.avsforum.com/avs-vb/showthread.php?t=928945&page=4 for my post #108 for a step-by-step solution with pictures. $21.83 is all it cost me. I fixed my own TV as many others on that forum have. Feel free to contact me at [email protected] if you run into difficulties. -Dave
Your tv sounds fairly normal to me - there is a difference between a tv being switched off and being on standby. It is usual for a tv to need to be switched on manually and from there the remote would be able to switch it between on and standby.
Sometimes the "power" button of the remote only switches the set to standby and selecting a channel would switch it from standby...
Is there power to the receptacle it's plugged into?
Is it a GFI receptacle if so has it switched off? It could need resetting.
Are you turning it on at the remote? Try turning it on from the TV itself. Maybe the remote is not operating properly.
This is a frustrating problem, but more details are required to solve it. Have you found the power switch on the TV? Are the batteries installed properly (facing the right way) in the remote? Is the TV connected to a working power circuit? If power is getting to the TV and the power switch doesn't work, I'd return the TV.
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Switch off the TV from remote, then switch off the on/off button on the TV, remove the plug pin from the power outlet. Cool off for 48 hours and then retry. If nothing works, better refer it to a qualified service technician.
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work • If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then turn on again. If this happens frequently, the voltage in your house may be abnormally high or low. • Unplug TV. Wait five minutes. Plug it in again.
Your T.V. is programmed to store the last input you've selected. You have to manually switch it back to your T.V. channel input after each time you switch it to HDMI or any other input even when you turn it off. The "Source" or "Input" button on your original T.V. remote will change this.
Hi there ,i would get a new remote control from a KONKA dealer ,they are not too expensive ,just give them your tv model # and your problems will be solved ,thank you for using FIX YA .
