Question about Nokia 3330 Cellular Phone
How to identify Ic defect
Is it any code to detect certain IC problem...such as nokia 3315...there are 3 parts of IC...Hagar..Ccont and Cobba
    New Friend:
Hot to use hagar ic in nokia 3315
Posted on Mar 13, 2013
No ic in 3315 all tune
Posted on Oct 31, 2008
Nokia 8250 no signal
if you recently accidentally drop your phone then you need to open it and reheat the cobba i.c or known as the audio i.c for some cellphone experts. you need to have the following things. hot air and a flux. first you need to put on a flux above the audio or cobba ic and reheat it using the hot air. set the hot air to its proper setting and slowly reheat the audio ic for 2 to 3 minutes. and then let it cool for 3 to 4 minutes and then close back your phone. then for sure it gonna have a signal.be careful of reheating the audio or cobba ic. since its sensitive and don't try to move it, just reheat it. coz if incase you move it, it will cause you phone to recieve a contact service error.
Jul 10, 2011 | Nokia 8250 Cellular Phone
3315 not charging
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Secend Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Thanks
Sep 01, 2010 | Nokia 3315 Cellular Phone
3315 not charging
First Option:
Secend Option:
Aug 25, 2010 | Nokia 3315 Cellular Phone
My 8250 is not power
according to my previous experience most of these models can not be switched because of problems in cobba ic, the ic cobba too step aside, too often affected if the phone down. This can cause the cobba ic Solder balls off easily. Steps you should take a trial is that you need a little mamasukkan Solder flux at the bottom of cobba ic, then heat with a hot blower. when warm, gently press the surface of the cobba ic. Note: - Do not be too hard, if not you need a new change if you do cause pressure Solder ball attached to one another (Solder shot).
May 12, 2010 | Nokia 8250 Cellular Phone
Sim card failed registration
YE PROBLUM HAGAR IC SE AATA HAI CHENGE HAGAR IC 100% OK
Jan 25, 2010 | Nokia Cell Phones
Signal problem
reheat or change antenna switch and power amplifier one at a time..if it doesn't work reheat hagar, ccont, cobba...
Jul 10, 2009 | Nokia 3315 Cellular Phone
Our nokia 3315 mobile is not charging ,what is the problem?
Check first your charger unit for cut or loose connection. If you can clean your unit's board this could help. But if the charger IC is shot you better bring it to a cellphone repair shop.
Apr 11, 2009 | Nokia 3315 Cellular Phone
As my experience, no power and no signal, i just re-heat on cobba ic, the place as drawing show.
Nov 27, 2008 | Nokia 8210 Cellular Phone
N70 network
simple, reset your settings or soft reset but first backup your phone memory when finished get your mmc and resetnit....
Dec 07, 2007 | Nokia N70 Cellular Phone
Nokia 3330 Cellular Phone Logo
141 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
