Question about Dryers
Kenmore gas dryer,belt replacement
How do I replace a belt on a kenmore 70 series ,gas dryer?
  • 4 more comments
  • Anonymous Mar 28, 2008
    can not get belt on
  • Anonymous Apr 13, 2008
    Kenmore dryer burning smell
  • bustbailbrut May 05, 2009
    I cannot get belt on. It was broken so I do not know how to replace.
  • Anonymous Mar 16, 2014
    Kenmore 70 Series model 110-67732794
  • Anonymous Mar 18, 2014
    barely rotates and sqeaks
  • Anonymous Mar 29, 2014
    replace the dryer belt and now it will not start
4 Suggested Answers
Ben-mrfixit
  • 68 Answers
SOURCE: Belt on my Kenmore series 70 dryer broke. How do
broken belt......simple fix.......remove lint filter from top 2 screws remove.........insert screwdriver between top & front push down to pop top......1 screw on each side holding front on at top remove them....front will then pick up off the 2 remaining clips at the front bottom.....spin door around to the side belt should be laying in the bottom of the dryer or around the tub but broken.......hope this helps......check back.......
Posted on May 05, 2009
mkh5094
  • 145 Answers
SOURCE: how do i replace the belt on my model 70 series kenmore dryer
You need to remove the dryer casing so the drum is viewable. You need to release the tension on the tensioner pulley and slide the belt off the pulley, then you can slide the belt off the drum. Replacement is the same as removal. The tensioner pulley can many times be accessed through a compartment in the rear of the dryer.
Posted on Apr 27, 2010
erpaalai
  • 999 Answers
SOURCE: I have a kenmore 70 series gas dryer. It won't
Check the thermal fuse and thermostats first, then the ignitor and the valve coils are the next possibilities.
Eric
Posted on Jan 24, 2010
How do i replace the belt on my model 70 series kenmore dryer
Apr 26, 2010 | Kenmore 62602 Electric Dryer
Kenmore propane dryer 70 series does not lite
Assuming the gas is on. The most likely problem is a bad ignitor. Remove the bottom front panel(pop 2 clips at the top of lower panel with a flat screwdriver) and turn the dryer on Look for the ignitor to glow. If the ignitor does not glow test leads to ignitor for power if you have power replace it. If the ignitor glows then you are not getting gas check to make sure the gas supply is on.
I hope this helps if you need further assistance please let me know.
Apr 14, 2010 | Kenmore Dryers
Eric
Jan 24, 2010 | Kenmore 63942 Dryer
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
Kenmore electric dryer series 70, on the inside of my dryer there is a plastic white ring that is cracked and brittle, clothes get stuck on this ring and tear, can I replace this white ring?
Yes, you can replace that ring.
I believe you have a front loading machine, if so then you will need to remove the front of the machine to expose the ring, drum and belt.
Try this website and see if they can supply the part you need.
Good luck, I hope this helped
http://www.partsselect.com/
Oct 03, 2009 | Kenmore 73952 Gas Dryer
May 05, 2009 | Kenmore Dryers
Belt replacement
Take the belt with you to an appliance store and they will match it up. Much like a fan belt on a car. You won't necessarily need the model if you have the belt. Next, it sounds like your assembly is broken. If this assembly looks to be in pieces, you may need a new one.
Feb 03, 2009 | Kenmore 73952 Gas Dryer
Kenmore series 70 dryer gas model 76712693-76712 squealing
Raise the top.
Remove the front panel.
Remove the drum.
Remove and replace the drum rollers and the belt tension roller.
Jan 20, 2009 | Kenmore 72982 Gas Dryer
Kenmore 70 series electric dryer runs but won't heat up?
Hi!!! If the unit is electric your heating element needs to be replaced if its gas then replace the coil boosters located on top of the gas valve..Good luck..
Jan 04, 2009 | Kenmore 73952 Gas Dryer
Dryers Logo
893 people viewed this question
Top Dryers Experts
