LG LS-L1210CL 12000 BTU Cooling Only Mini Split Air Conditioner
Problem for LG LS-L1210CL 12000 BTU Cooling Only Mini Split Air...
My mini split turns on but is not cooling.
By anaissuleymi on Oct 28, 2009
My mini split turns on but is not cooling. It comes and goes... sometimes it cools, and the majority of time it doesnt. Plus, is leaking water. I live in an island and is hot! I need help!
Best Solution
posted on Oct 28, 2009
Very Helpful)
shastalaker7
Rank: Guru  Air Conditioners  Expert
Rating: 89%, 64 votes
With out looking at it, I can give you some ideas that could cause these problems. I need to know where the water is coming from? If it is leaking on the inside, this narrows it down some. It sounds to me that the evap. coil is icing up which the unit could be low on freon, you're indoor fan motor may not be running up to speed, a dirty filter or evap. coil. You need to shut the unit off, maybe through the night. Get a latter and remove the cover on the indoor unit. Check and wash the foam filter and look the coil over for excess dirt build up. Leave the cover off for now, and go outside to the outdoor unit. Have someone turn the t-stat to on. Watch and make sure that the outdoor fan stays on and listen very close to see if you can hear the compressor running. It sounds to me that one of the named items I have listed is causing the evap. coil indoors to ice up and blocking the air flow to you're home. Let it run with the cover off and just watch it for a few hours. If it starts to ice up and the filter is removed with cover, and the indoor fan is also blowing air, more than likely, you have a small freon leak which is causing the problem. If I were there, I would know in a few min. what the problem is. As far as the leak, it is the ice melting off and running over and the condesate line may have a partial plug in it. If it is low on freon, you can go outside and put your hand on the larger copper line to see if it is warm. It should be sweating or condesating if it is charged properly. If warm or barely cool, more than likely it needs a charge and leak check.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" thank you very much for this full answer! very helpfull, i will do as you say! thank you so much!!!!! :) " - anaissuleymi
Popular Solutions for LG LS-L1210CL 12000 BTU
Questions and Unsolved Problems for LG LS-L1210CL 12000 BTU
Do you recommend LG LS-L1210CL 12000 BTU Cooling Only Mini Split Air Conditioner?
Answer
Answer
My LG LSL121N-2 problems is stop working and indoor unit flashing five blinks.Please send me a fault... (More)
Answer
I have an LG room a/c Model # LWHD7000HR that cools for a while then the compressor clicks off and... (More)
Answer
i have two similar units (lg mni split same model), one works fine and the other no with the same... (More)
Answer
Dog destroyed the remote control unit. Need help on where to find it. Nelson
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For LG LS-L1210CL 12000 BTU...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
