Question about Dryers
Amana Electric Dryer; Model Number LE4607W
I have an Amana Electric Dryer, Model Number LE4607W. When I went to open the light flickered. It stopped in the middle of the drying cycle, and when I turned it on (with the knob) it made a loud grinding noise. Now, when you push the knob down, it makes a humming noise, but the drum does not turn. You can turn the drum manually in one direction. Is the problem with the belt, or the motor?
Thanks!
Hallo.
Posted on Jan 03, 2008
My Amana Electric Dryer Randomly stops working and it won't start up again , it can take up to an hour for it to work again. Model Number LE8407W2.
There are safety sensors that will break the current when it gets too hot or if the sensors themselves are failing. This will shut the dryer off or make it quit heating. After cooling down or at random times the sensor may make connection again allowing the dryer to work. These can only be checked out using an OHM meter and must be checked when they are not allowing the dryer to run.
Jan 22, 2013 | Amana Dryers
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
Belt worn out - need to find the model number: amana heavy duty gas dryer - limited edition
you gave the model number it's NDE6800AYW,the belt part number is 33002535 and it's around 25 bucks
Jul 31, 2010 | Amana NDE6800AYW Electric Dryer
Dryer won't start
On the bottom left is the heating element. On that element is a limit. If open the dryer will not run.ba9d1b0.jpgHere is an amana late model service MANUAL:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 07, 2010 | Maytag MDE308DAYW Electric Dryer
Amana Dryer model # LEA60AW. Dryer runs but no heat.
check the heating element and the high limit fuse
Jul 10, 2009 | Amana ALE643RB Electric Dryer
I have Amana electric dryer, model number LEA30AW. How do I open the dryer to check the belt and the motor?
There are 2 screws along the bottom and the lower panal will drop down and off. You can look in from there.
Eric
Jun 10, 2009 | Amana Dryers
Dryer work turn on, buzzes when start is pushed
It may be just your timer switch. Look at all the wiring first. The receptacle to the plug, cord and into the back of the dryer.
Feb 15, 2009 | Amana Dryers
Dryer does not turn on
Sounds like the motor relay is not functioning. Sometimes the motor will work if the button is pushed but will stop when the button is released. This is caused by a loose wire at the motor or a bad motor relay.
Oct 18, 2007 | Amana DLE330RAW Electric Dryer
Dryers Logo
163 people viewed this question
Top Dryers Experts
Marvin
Marvin
