Home | Garmin | Edge 305 GPS Receiver | Cadence function qui...
Garmin Edge 305 GPS Receiver
Problem for Garmin Edge 305 GPS Receiver
Cadence function quit working on Garmin Edge 305.
By geo86 on Oct 28, 2009
Cadence function quit working on Edge 305. Replaced battery on GSC10 chainstay unit, sensor light begins to flash but dies and unit does not pick up or show cadence.
Solution #1
posted on Oct 28, 2009
Not Rated)
super_guy
Rank: Guru
Rating: 97%, 7864 votes
Try this to see if it works...
  1. Change the battery in the cadence sensor. (which you did)
  2. Turned on armin 305 edge outside to acquire satellites (probably not necessary)
  3. Press reset on the GSC10, and it should flash red and green
  4. On the Edge unit, go to SYSTEM.
  5. Under SYSTEM, scroll to bottom, choose ACCESSORIES.
  6. Under ACCESSORIES, scroll to bottom, under Cadence Sensor, to the option RESTART SCAN.
  7. Press RESTART SCAN.
If that doesn't work, you may have to fiddle around with the sensor. Try moving the GSC10 as close to the crank sensor as possible, then tilt the GSC10 slightly towards the crank. You'll have to forgo using the spoke sensor to determine your speed as it's already calculated by the GPS function.
Popular Solutions for Garmin Edge 305 GPS Receiver
Questions and Unsolved Problems for Garmin Edge 305 GPS Receiver
Do you recommend Garmin Edge 305 GPS Receiver?
Answer
Answer
My edge 305 doesn't always pick up sallelite. I use it on my bicycle and it fell off adaptor onto... (More)
Answer
I will be riding a 340km 24 hr mtb stage race consisting of 6 stages in dec. How do I manage... (More)
Answer
my garmin edge 305 freezes up during the ride on occasion. the distance and elevation numbers just... (More)
Answer
Device shut off due to low battery and never charged again
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Garmin Edge 305 GPS Receiver:
Top GPS Device Experts
Rank: Guru Guru
Solutions: 14739
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more GPS Device Experts
Top GPS Device Repair
(281) 371-2722
GeoQuip is a "One Stop Trimble Repair...
Gulf Coast GeoQuip
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
