LG GCC 4520B CD-RW/DVD-ROM Burner
Problem for LG GCC 4520B CD-RW/DVD-ROM Burner
I can not install the driver
By henrique_ted on Oct 28, 2009
Best Solution
posted on Oct 28, 2009
Very Helpful)
kcsc
Rank: Apprentice
Rating: 100%, 1 votes
Quite a significant number of users are having the same problem and all sorts of ideas are being thrashed about. Some fixes seem extreme and others are lengthy. Working thru the issue so far I have found it is not a dvd driver issue and is not a bios setting issue or a faulty ide cable. I wish it was that easy. I am now leaning more towards it being an issue with the ide detection in the setup. First off make sure all your drivers are up-to-date for your motherboard especially the ide/ata drivers. I thought mine were but when I checked windows update it had them in there as optional downloads. I also used driver genius so I could refer to the drivers independently during windows 7 setup. However, it still FAILED. I am now thinking it could be because I am using a dual ide cable for my main hdd and dvd. I would seperate them so they run on independent cables but only have one ide slot on the motherboard. So I am going to have to install windows onto a raid/gigabyte driver and use the ide cable just for the dvd then give that a go. I am thinking it is this that is causing the error with windows 7 because I had a similar issue with installing vista with a motherboard that used raid/gigabyte hdds and it did not like it. We had to use a pci card and run the drives from that as vista would not detect them plugged into the mb. Hope this may help. Those error messages with ms are never as clear and obvious as they seem but I certainly would not go getting a new dvd drive thinking that will fix the problem because it could be the ide setup.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Not Rated)
chamboard
Rank: Wiz
Rating: 82%, 160 votes
no need to instal driver windows wil see all type of cd cdrom writers and readers i think you configuratie on start up from pc in the bios are the option disable so start up pc and hit del or f2 or the keys thad wil give you acces to bios google on the web for bios access
and select auto save bios and startup again
in the startup sreen wil appear hd,cd/dvd, memmory and all the settings from the motherboard if cd/dvd not display contrl cable and power from device
Was this helpful?
Yes
No
Solution #3
Not Rated)
dnewcombe1
Rank: Guru
Rating: 86%, 456 votes
If you only have one player/recorder than you'll have to go to the manufacturers site and download the drivers and software from the "Support" section under "downloads". Thanks,Dana P.S. You may also use a flash drive.
Was this helpful?
Yes
No
Popular Solutions for LG GCC 4520B CD-RW/DVD-ROM
Questions and Unsolved Problems for LG GCC 4520B CD-RW/DVD-ROM
Do you recommend LG GCC 4520B CD-RW/DVD-ROM Burner?
Answer
Answer
How do I get Insignia CD NS-P4112 to start? I put in new batteries and plugged into the ''phone''... (More)
Answer
packard bell pentium 4.hitachi dvd rom playr.used to burn cd but now asks to conect separate burner... (More)
Answer
dvd duplicator disc in the trays but it says target drive not ready
Answer
my cd burner only burns about 2/3 of of the songs from i tunes
Answer
My system detects only VCD's but does not detect and dvd. So I cant run any DVd format movies.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top CD and DVD Burners Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
