Washing Machines
Generic problem for all Washing Machines
Maytag washer that stopped working
posted by Shmuelik on Jan 02, 2008
The washer is not pumping water into the chamber when it is turned on, the water inlet valve is open. Is the pump gone? can it be anything else, Please help.
Thank you,
Shmuel
Comment posted on Jan 03, 2008
The washer model is Maytag top load washer model MAH4000AWW and I found that they have a history of issues with the wax motor caused by a resistor and triac blowing on the control circuit, in fact this is a subject of a class acion law suit. I opened up my washer and indeed the R11 resistor is blowen, I am going to replace it and the Q6 triac and see if that takes care of the issue. Do you know if there is a service manual that tells you how to take the top cover off and the sides.
Thank you for getting back to me,
Regards,
Shmuel
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jan 02, 2008
Helpful (85)
vest6
Rank:Guru Guru
Rating: 88%, 151 votes
If I understand this you seem to be having problems with the water valve. Please check each valve by selecting cold water and see if there is any water. Next do the same for hot. Also, need to know if any of the other cycles are working. There are several conditions that can cause the trouble you are having. Please list your model and serial number as this combination will tell us the manufacturer of your machine. Maytag did not manufacture all thier brand name units.
Comment posted on Jan 10, 2008
Yes, this machine does have a history. ( The class action suit does not pertain the the wax motor though. It pertains to the mold problems of the door and boot.)
What you are refering to (R-11) is used to control the wax motor at the door. This motor will have to be replaced or your repairs will mean nothing. Do you need instructions on how this is done?
Rating Locked! (?) Shmuelik has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Maytag washer that stopped working:
I don't want to Accept this solution
Can you Help with these Washing Machines problems?
GE WJSR2070B Top Load Washer
wjsr2080t2ww GE will not spin with the belt off I think it...
GE S8000E
Washer model GE WLE4000B1WW the push start button won't...
Washing Machines
the brand is a Miele touchtronic W1213
Maytag Neptune MAH5500B Front Load Washer
The machine started draining water out of the door. The...
Whirlpool Cabrio WTW6600SBT Top Load...
My Whirlpool WTW6300 with the agitator shuts down during...
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Repair Service
Find Washing Machine Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
