Question about Philips 50P8341 50" Rear Projection Television
Phillips 50p8341 Projection tv no picture
Ok im pretty good with soldering and repairing electrical equipment but have absolutly no experiance with what can cause problems in a projection tv.
I have owned this tv since brand new never had any problems with it untill now 4-5 years later.. But first off the color and picture has had that green hue to it for quit some time and never really cared to look for a solution till now.. but thats not the problem im worried about
Problem : When i came home today i powered on my tv and got the Red Led power light has came on its sorta sounded like it was trying to turn on but failed to Fire up. So i started to check the problem. I opened the front of the tv took the screen off proceded to turn on and off then noticed that the Blue Light was not even lighting so i gave it a few taps and the light flickerd a bit. So then i proceeded to look around of course i turn the power off and unpluged. Well now i see that there was soo much dust in the bottom of the cabnet so i removed all the dust. Now i had shaken wires around hoping for a loose conector but no good. so i unscrew the main Bracket holding all 3 projectors and look underneth and i see the 3 bulbs wires etc . So i now want to see what happen when u turn on and when i do i see the green and red bulbs fire up but they did not fire up all the way meaning i have already seen it work for a few seconds when i tapped the blue projector all light got bright and could see picture then blue went out and i couldnet get it to come back on no mater what i did off on tap shake move wires etc. So now im at this point of saying what do i need to replace. Any help would be greatly appriciatted I still get power the red and green lenses are on but not really bright kinda looks like the bulb is warming up but never lighting. Now Is my blue bulb bad or some component ill try anything i would like to fix this tv.
  • SmokinTGP Jan 02, 2008
    well crt in as the blue light i guess u mean. well the Tv still powers on and when i turn it off i can see the picture for like 1 second. but the picture of course has no blue in it i did at one point get the picture to stay on without the blue crt working if this helps any reply again my
    MSN smokintgp@comcast.net
    AIM ear199
    please help i can explaine further if u like
  • 579 Answers
Looks like the blue crt is bad and may have killed the main power board that has the high voltage supply.
A new crt is almost $400 and my distributer shows the power supply as no longer available, but may be able to get it somewhere else. Plus you need the service manual to realign and converge everything (hope you didn't mess this up too bad). Really need to find a good rear projection tech to do all this, but may not be worth it.
Posted on Jan 02, 2008
Picture is not clear. Has a green tint and glow.
Repalce the coolant in the CRTs. You can get the Phillips CRT coolant replacement kit at www.tvrepairworld.com the kit contains the coolant and the CD with instructions
Oct 13, 2009 | Philips 50P8341 50" Rear Projection...
Phillips 50p8341a
Replace the coolant in the CRts thats a common problem with Phillips and magnavox rear projections. Heres a link to the coolant replacement kit for your model. The kit contains the replacement coolant and step by step instructions with pictures.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-crt-coolant-replacement-kit/cName/repair-kits
Jun 12, 2009 | Philips 50P8341 50" Rear Projection...
57H81 projection tv has very wiggly picture.
This is the Hyper Module that needs repaired. There are several small sm caps that dry out in this model. It's the module standing up to the right covered by a can as we call it. I really don.t recommend you trying to repair it. One slip and that module is done and you can't by a new or rebuilt one anymore. Please let a repair center look at it and do the work. You won't regret it.
Mar 08, 2009 | Toshiba 57H81 57" Rear Projection...
Philips 50P8341 50 in. Rear... Problem:
You CRT coolant needs to be replaced, its a very common problem with the phillips and magnavox projection TVs. If you need more info on the Coolant Change let me know.
Jul 14, 2008 | Philips 55P8341 55" Rear Projection...
Philips 50P8341 50 in. Rear Projection Television
Sounds like the blue convergence IC s bad. They are relatively easy to replace if you can solder they cost around 10.00 each and you should change both the red and the blue.
Feb 09, 2008 | Philips 50P8341 50" Rear Projection...
Phillips model 50p8341 titanium-finished 50-inch Red tint to picture
Your Red CRT may be on its way out. Try turning down the G2 screen control on the red CRT just a little. That should help for now. A new red tube wil be a reality in the future.
Jan 21, 2008 | Philips 50P8341 50" Rear Projection...
Blue screen with sound but nothing else!
I, too, acquired a Phillips without a manual and was experiencing a similar problem. My model is PTV 916, but if your TV has a "source select" button, say a prayer and press the button. From that point, I don't know what else I did, but I do get TV programs now.
Jan 04, 2008 | Philips 50P8341 50" Rear Projection...
Phillips 50P8341 50"
replace the convergance amp ic's
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
· http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
· http://www.hdtvoice.com/voice/index.php?s=
Jan 02, 2008 | Hitachi 53UDX10B 53" Rear Projection...
No picture, sound ok
you need a new flyback.
that is the problem.
Nov 11, 2007 | Philips 60PP9202 60" Rear Projection...
Philips Projection Tv (50p8341)
take a real good look at the quality of the picture you have now b4 putting any money into this product many of the phillips projo tvs out there have burned fluid in the crts that needs to replaced also up to an including new crts the convergence amps are the black things that say stk392-110 on them two of them that would would get you customer convergence back again do you know how to solder?
Dec 07, 2006 | Philips 50P8341 50" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
105 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
