I have a HP LJ P2015n. Should be on our network and currently the printer has a different IP. I am connected to the printer currently via usb to change the ip, but it will not keep the ip when I change it.
As i understand your concern you have network printer which you want to setup with your network. And right now your printer is connected with the computer using a usb be cable. Thats the main reason why it is having different ip address because it don't required any ip address once you tried to connect your printer through usb cable. I can suggest you that once you connect your printer on the network and you will get the option to network setup on your printer where you can assigned static ip to you printer which is the range for your router or network device called DHCP.
I believe that will help your resolve your concern.
I have an HP 2015N, and I want to share it on a PC network, so that an Apple Mac laptop can see it...
(More)
I have an HP 2015N, and I want to share it on a PC network, so that an Apple Mac laptop can see it accross the network. I have set up printer sharing but the laptop still cant see the printer, any ideas? many thanks Tim
Okay, so my toner is full, I have ben printing fine all morning. Then I go to print envelopes and my...
(More)
Okay, so my toner is full, I have ben printing fine all morning. Then I go to print envelopes and my problems start. I was able to print ONE, but after that the printer pulls the envelope through but does not print on it. The triangle is flashing, and the toner light is steadily on. However, as I said earlier, my toner is still full. ???? Any ideas? I've already taken the toner out and placed it back in and turned the printer off for several minuets with no avail.
I am installing HP laserjet P2015 , but can not the response is the extended attributes are...
(More)
I am installing HP laserjet P2015 , but can not the response is the extended attributes are incorrect. This printer was working fine in my office and it less than 6 months old
we have a p2015dn printer but the rollers are making a noise can u help when the paper is going...
(More)
WE HAVE A P2015DN PRINTER BUT THE ROLLERS ARE MAKING A NOISE CAN U HELP WHEN THE PAPER IS GOING THROUGH AND THEN IT STOPS WHERE CAN WE BUY THE ROLLERS
