Emerson EWD2202 DVD Player / VCR Combo
Channel Setup
posted by Primolovito on Jan 02, 2008
I have the unit hooked up to an antenna but when I go through the Automatic Setup, it keeps recognizing the input as Cable rather than Air. Is there a way to manually change the channel setup- I can't find anything like that in the Menu. I've tried the setup with no input as well and it still insists that it's getting a Cable signal.
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Feb 01, 2008
Not Rated (0)
crawdaddydoo
Rank:Apprentice Apprentice
Rating: 100%, 2 votes
it's saying that because the antenna is hooked into the same thing, the coaxle jack. It shouldn't memorize any chanells that don't come in on the antenna. It's been a long time since I had mine hooked to an antenna but I know it'll work if you let it go through the auto setup. If need be unplug the unit for like two minutes so it's memory is erased and then fo form there. I hope this helps
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Channel Setup:
I don't want to Accept this solution
Can you Help with these DVD Players problems?
pull front plastic cover from unit--look on front right...
Emerson EWD2202 DVD player shows cable picture with fuzz...
The remote for my EWD 2202 Video Cassett & DVD/CD...
The VCR part of the combo will not play VHS. Earlier today...
All other DVDs I insert into our Emerson DVD/VCR combo...
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Help us help you.
Take a brief survey and help us improve the site.
Your opinion counts!
Repair Service
Find DVD Player Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
