Home | Epson | Perfection V100 Flatbed Scanner | Epson Perfection V10...
Epson Perfection  V100 Flatbed Scanner
Problem for Epson Perfection V100 Flatbed Scanner
Epson Perfection V100 photo scanner issues
By bailey_mandy on Oct 28, 2009
Epson Perfection V100 photo scanner issues installing to XP operating system installed with service pack 3 can yoou assist please?
Solution #1
posted on Oct 28, 2009
Not Rated)
ginko
Rank: Guru  Epson Computer Hardware  Expert
Rating: 89%, 5025 votes
Hi.
The driver software must be installed before connecting the scanner to computer, or installation may fail.
If you have plugged in USB before installing software, then remove the installation doing a system restore to one day before you installed the scanner. Reinstall the scanner afterward.
You find system restore at: Start>Programs>Accessories>System Tools>System restore.
  • Chose one day before scanner installation, and restore to that day.
  • After restore , restart computer keeping USB cable to scanner unplugged.
  • Download all software and drivers here :Epson Perfection V100 Photo, Drivers & Downloads
  • Install drivers starting from Twain Driver.
  • Plug in USB only if asked by installer program
  • Restart computer after installing, and plug Scanner USB if not done already on setup wizard request.
  • Possibly use a different USB port, if you have a replacement USB cable also test it.
  • Ensure that firewall and security software has been disable throughout the whole process.
  • Ensure that you installed all scanner software. If you install Twain driver only the scanner will work, but you will need to use an external application to acquire scans.
If still no luck, then there may be a an issue with the recently re-released service pack three (SP3 is 3 yrs old). In that case you can uninstall SP3, reinstall drivers, and reinstall SP3 on top. There are device drivers that had not been tested on SP3, and sometimes this can cause installation troubles.
Best regards.
Popular Solutions for Epson Perfection V100 Flatbed
Questions and Unsolved Problems for Epson Perfection V100 Flatbed
Do you recommend Epson Perfection V100 Flatbed Scanner?
Answer
Answer
how to scan a document into pdf using epson perfection v100 scanner? i push the pdf button, nothing... (More)
Answer
When I scan a large image using the whole face of the scanner, it leaves a stretched/blurry stripe... (More)
Answer
After the Espon V100 scans the photo it says: Unable to write the file. Help! :)
Answer
I am getting banding down each page (wide vertical streaks).
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Epson Perfection V100 Flatbed...:
Top Scanner Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Scanner Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
