Question about Hoover HTC243 Top Load Washer
Hoover 800 heavy duty washing machine
Washing ok, not rinsing or spinning to capacity, loud clicking thru the cycle, what does the reset tab mean? is this to reset the cycle or the water llevel? where is the outlet pump and the filter I have no manual this is mums machine...help
How will you know when the brake arm needs to be replaced? Is it fixable or will I need to get a new machine?
Posted on Sep 01, 2008
Hi then can u help with this washing machines i just got it it 800 ac268 ,ac270 i am try to put it on with put in the water to see if it will work but notring happed with in if u can get back to pz on my email it is amandahebbo@yahoo.co.uk thanks a lot pz
Posted on May 15, 2008
    Sergeant:
  • 351 Answers
The clicking sound could be the brake arm worn its white and in the middle near the gear box,the reset is for water only.the outlet pump is at the back where the drain hose comes out.the filter is in the middle of the agitator just pull it out.check the belt isnt loose.
Posted on Mar 02, 2008
What is the capacity size of washer model fws1339ac1
Dimensions/Weight/Electrical Height: 43 5/8" Width: 27" Depth: 27" Approximate Shipping Weight: 180 lbs. Electrical Requirements: 120V/60Hz. Features Control Location: Top Console Capacity: Super Capacity Tub Size (cu. ft.): 3 Agitator Style: Twin Spin Cycles: 13 Wash/Rinse Temperature Combinations: 3 Motor Speeds: 2 Heavy Duty Motor (Hp): 3/4 Total Front Serviceability: Yes
Aug 30, 2012 | Frigidaire FWS1339A Top Load Washer
Kenmore Heavy Duty 80 Series Extra Capacity Plus Model# 92480200. The washer will begin to fill and will not stop filling regardless if water level setting is on low, medium or high and will overflow and...
The problem is the pressure switch has failed or the hose is plugged up, has a hole in it. These are usually inexpensive and are very easy to replace. Here is a video this will walk you thru testing and replacing a pressure switch. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
Oct 30, 2010 | Kenmore Washing Machines
We have a Hoover select 1500 washing machine. It still washes and rinses ok, but doesn't then move onto the spin cycle. But I can manually set the dial to spin and restart it. It then spins fine. I assume...
Could be but also could be rinse water valve not operating due to faulty solonoid. it does a final rinse / softner before spinning if valve faulty then no spin advance....
Nov 11, 2009 | Washing Machines
Rinse cycle do not disengaged
does it drain?did you check the lid switch?
May 17, 2009 | Kenmore Washing Machines
Stoping on rinse cycle
your lid switch is bad. can take a pen and push it up and down to hear if it clicks. may want to take it off and see if it has split. very easy to do. if you need help i can walk you thru it.
you can take a jumper wire and try putting it in both ends of the plug coming down off the machine. you can strip both ends of a wire and that will be your jumper. all that is doing is by passing the lid switch. do not put either end in center of plug. plug machine in and make sure the wire is not going to hit against frame and turn machine to spin and on.
any further question let me know,
thanks.
Mar 29, 2009 | Washing Machines
Inglis Washing Machine - Heavy Duty Extra Large Capacity
if it doesn't empty check the pump for blockages or just not working electrically, or check cold water supply to machine, or the cold water solenoid, this may also be faulty hope you can find what you need starting from the above, if i have helped please rate me
Oct 04, 2007 | Washing Machines
Agitator
if its a 2 piece agitator.. the gears in top of agitator is stripped out.. change gears be like new....spin top countor clockwise if it dont grap.. gears bad
Sep 28, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Hoover HTC243 Top Load Washer Logo
587 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
