Question about Cyberhome CH-DVD 300 DVD Player
Resetting failed I probably set to a mode my tv doesn't support. So I tried resetting as explained in solution of this problem in the manual, but I still can't visualize the DVD image or setup menu, only sound. What can I do?
  • 1 more comment
  • Anonymous Jan 04, 2008
    I set to a mode my tv doesn't support. So I tried resetting as explained in solution of this problem in the manual, but I still can't visualize the DVD image or setup menu, only sound. I press and hold the stop button for 30 seconds and still no visual. What can I do? Gabriel of NY
    What can I do? GABRIEL
  • jabby358 Mar 16, 2008
    when i put in a disc to play it starts loading and then stops and Baddisc comes on i also changes setting in video window ,now all i get is black picture i dont know if sound is working either is there a reset i can go to i can not find my manual any help would be much appreciated
I reset all to the manufactor's defaults by:
Push setup
right(GREEN) 3 times
<enter>
down 4
<enter>
turn off player
try player
Posted on Apr 18, 2008
    Problem Solver:
  • 9 Answers
Push setup
right(GREEN) 1 time
down 2
right 1
up 1
enter
turn off player
try player
Posted on Mar 15, 2008
How to fix issues whith component outputs on haier hlh26atbb 26 in. lcd ?
When you make the connection with HDMI are you changing the source or input key on the television to activate HDMI port? If you don't activate the corresponding source you connect to and leave the TV in the TV mode, you won't actually see the device you are connecting. It's possible the TV does not support the 1080P from your PS3.
Apr 17, 2015 | Haier HLH26ATBB 26 in. LCD Television
Power off
Just look in the menu options for "Sleep mode" and set it to OFF! If that doesn't work, try unplugging the television for an hour or set. That usually resets it to the factory default setting. You might be able to reset it by looking in the menu options and select "Factory Reset" and that should reset the Sleep mode. Hope that helps!!
Oct 20, 2012 | Panasonic Viera TH-42PX80U Plasma TV
I have a sony bravi xbr ;the picture is sooo big i can't read the subtitles . i tried ti fix it ( from the instruction manual ) but nothing work . thank you !
Hi: Check you screens format button to change screen sizes, this button may also be labeled Aspect. Seems you are in ZOOM Mode, these buttons can also be found on cable boxes remote as well try pushing them to see if screen size change. If this does'nt help then do this with the TV in off posistion. Press the Display key on your remote, Then the Five key, then the Vol up key, then press power key. This will turn set on in service mode, you will see service options do not do anything but press the number 8 on remote and hit enter. This will rest tv to factory settings. All video setups and parameters you have set in user menu will result back to factory and will need to be redone. TV should shut down on its own and come back on on channel 3.
Dec 10, 2011 | Sony BRAVIA KDL-52XBR3 Television
Our picture will only show reds and greens, no other colors.
Go to your On Screen Menu to picture settings and reset and choose "reset picture" mode. This will bring you back to factory defaults. If this doesn't work shut off wait 10 sec. and turn on the TV. If still no luck call your best friend who is a TV repairman, you probably have a damaged blue drive.
Oct 02, 2011 | LG 32LG30 32 in. LCD HDTV
The television stays in closed caption mode regardless of the settings. Is there a way to reset it to factory default
try turning off the caption through the remote of the menu. to reset it to factory settings, go to menu, then settings, then there should be an option to reset the tv. If this doesn't work look through your manual. Sometimes you have to hold the power button for some length of time or the menu button on the tv. if these methods don't work, tell me the model and make of the tv.
May 28, 2011 | Televison & Video
I am attempting to hook up the dvd player to the tv and it doesn't work
Have you read the manuals for both? It's probably explained except I'll bet the unnamed TV manual didn't anticipate someone wanting to use the TV as a speaker system for an audio-only device. The TV has at least an analog audio input. Treat the CDR as a DVD for the hook-up. There's probably an illustration.
May 26, 2011 | Sony RCD-W500C 5-Disc CD Recorder
Why are the people shorter & fatter on my screen?
Find the remote contol button said as P.mode or view mode changes it to normal.The people should back to normal,not shorter or fatter anymore.
Sep 06, 2010 | Samsung UN46B7000 46 in. LCD TV
TV will not remember settings Sony Bravia KDL 40S4011
Probably you are in "shop" mode of TV. Try to reset your TV and go through initial setup. Most important - choose "home" instead of "shop" when asked during initial setup. Resetting - keep up arrow pressed and switch of TV. Keep the button pressed when TV automatically switch back on. This will reset TV to factory defaults.
Apr 17, 2010 | Sony BRAVIA KDL-46V3000 Television
42hp66 toshiba will not change channels sits on channel 27. I do not have cable but the signal feeds other tv and this one was working this morning
I would say this has a software issue with the Eprom ic, I would try to get in the service mode and reset it to factory settings ( Google your model for service mode )
Failing this it will probably need a replacement av main board.
Mar 05, 2010 | Televison & Video
Turning off Video2 without remote.
HI:Leeray53
THE MEMORY EEPROM WILL BE CHANGED
PROBABILITY IS DAMAGE,
THAT RESET TO DO IT MODE ORIGINAL
FROM LUIS
Nov 17, 2007 | Sanyo DS20930 20" TV
Cyberhome CH-DVD 300 DVD Player Logo
107 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
