I updated my windows xp and then there is a warning that dont shut down it and nnfortunately I disconnected the power to the computer and then the when i switched it on it screen is black and there is no dislplay only the black screen
switch on the laptop...>press F8...>select last good known option. and check.... you can start with safe mode ..... if its not working reinstall the os.....
I have an ASUS F5RL-X3 I can not access the recovery console using F9, nor can I repair it using OEM...
(More)
I have an ASUS F5RL-X3 I can not access the recovery console using F9, nor can I repair it using OEM WIN XP Pro disk. I have changed boot priority so that CD is first device however it goes to HDD. I just want to get it started in recovery or DOS so tat I can manually fix registry and run chkdsk /p/r. F9 does not work!
wont allow facebbook access , have set all the interbet settings to factory settings, cant do a...
(More)
wont allow facebbook access , have set all the interbet settings to factory settings, cant do a restore as not enough memory, taken of AVG as was told thats the porb, trying to sort out a friends one and its just not having it
I have an asus eepc and a few months back I installed Windowz xp in it. However, I cannot connect to...
(More)
I have an asus eepc and a few months back I installed Windowz xp in it. However, I cannot connect to the internet. How can I fix this problem?
