Question about Sceptre X20G-Naga II 20.1" Flat Panel LCD Monitor
ACER AL 1912 Colors bad screen shakes
My Acer AL 1912 started having bad colors and a shaky screen. The colors seem washed out. It is not the video card, the computer, or the settings. It does it no matter what after about 1 minute. I want to open it and replace parts but what part might it be?
Ken
rstein2@aol.com
  • 22 Answers
Your asking which part you want to replace. try first to check all the connections.
Posted on Feb 20, 2008
Video seems to be going out in my Acer Aspire 5520-5334 laptop. Can i replace just the card or do i have to replace to whole motherboard?
Graphics cards on laptops generally are a part of the motherboard. It may not be the graphics card however in your case. It could be a screen or cable. If there are lines on the screen / no video / or distorted colors, it will require a technician to open the laptop and perform evasive work. If it is truly a bad graphics card, then the best option may be to purchase a different laptop altogether.
Aug 27, 2013 | Acer Aspire Computers & Internet
Acer aspire 5720 graphics problems
When you say other monitor I'm assuming you are talking about an external monitor attached to the laptop? If so then you are correct if it shows the same as the monitor that is in the laptop, you have a graphics video card problem.
Apr 07, 2012 | Acer 5720-4126 PC Notebook
I have an acer aspire one d150 and is having
check your resolution in cotrol panel ok;
May 01, 2010 | Acer Aspire One PC Notebook
Acer 5735 wont start up. just stays on black screen. i have no recovery disk.
check your video card. Does your monitor light change colors when you boot it?
Sep 17, 2009 | Acer Aspire 5735 Notebook
Acer AL 1912 (black) resolution issue
[u][b]LCD Monitor Shadow Effect[/b][/u]
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
[u][b]Solution: [/b][/u]Keep the two cables - (power cable and moitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
May 27, 2009 | Acer AL1912 19" LCD Monitor
The picture shakes
install the monitor driver..you can find it in manufacturer's support link and also run the video and monitor diagnostic software to calibrate the colors...acer might have the software
Mar 13, 2009 | Acer X173WB Monitor
My acer notebook the screen has lots of colors it doesnot work
Restart in safe mode then check all your video settings. However this sounds like a damaged on board GPU.
Mar 07, 2009 | Acer Aspire 3680 Laptop
Screen flickers for about 20-30 seconds sporadically
Try looking at the LCD screen at a sharp angle to see if ghost-like video can be seen during the 'off' time of the flicker.  If video is still present even though not that visible, then either the backlight or its power supply are failing. The color problem could also be caused by a backlight lamp that is not ionizing completely.
Dec 14, 2008 | Acer AL1912B 19" LCD Monitor
INPUT NOT SUPPORTED
Is this on a Linux pc? I had this problem with a Viewsonic and Ubuntu. I had to play with the Horizontal Sync and Vertical Refresh till I got it right.
Aug 18, 2008 | Acer AL1916W 19" LCD Monitor
ACER AL 1716
There are two types of lines.
Lines caused by a bad LCD screen and lines caused by poor sync.
A bad LCD will cause perfectly straight vertical and horizontal lines that don't move at all. This is because the row and column addressing ICs have gone bad, so you will end up with rows or columns of bad pixels.
Poor sync looks more like what you are describing. The picture will flip vertically and horizontally.
Poor or missing sync can be caused by a bad video cable, or a bad IC on the main board.
If the monitor has a removable video cable, borrow another one from a friend to test if the monitor is working. If it works, head to your local computer store and buy a new cable.
If the monitor still doesn't work with a different cable, you may have a bad main board. The only way to repair the monitor will be to replace the board.
If you open the monitor, be sure to check for bad capacitors. They can cause all sorts of strange faults. Look elsewhere on this site for how-tos on inspecting capacitors.
If your video cable is not removable, there's not much you can do. You will need a way to test that each pin on the cable connector on the main board conducts to a corresponding pin on the other end of the cable. You can do this if you have a multimeter, or a continuity tester.
Mar 28, 2008 | Acer AL1716 17" LCD Monitor
Sceptre X20G-Naga II 20.1" Flat Panel LCD Monitor Logo
211 people viewed this question
Top Sceptre Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
