Question about Philips Magnavox 27MS343S 27" TV
TDA 8364 Hi  can  you pls give me the pin configaration of  TDA 8364  and which ic i can use equel to  this IC. Soman [email protected]
  • 579 Answers
Look it up at nteinc.net
Posted on Jan 02, 2008
6ya staff
SOURCE:
Tda 9370ps pls tell mr the Blue back pin
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Refer the circuit diagram. It is there. Surf the site with the number of IC " TDA9370 "as keyword.
Jul 03, 2015 | Televison & Video
Tip
Replace the kkz-12 power amp ic on kenwood car stereos
replace the kkz-12 ic[difficult to find expensive!]with the tda 7560!first desolder the kkz .have 27 pins.take the tda and cut the pins 1 and 25.replace the kkz with the tda now.let the pcb positions 1-2 and 26-27 pin empty.solder the ic put htc in the heat sink tight screws and check the unit!
on Mar 08, 2010 | Car Audio & Video
WHAT IS THIS PROBLEM R805 RESISTOR 33 Ohm BURNING how this solvation sharp tv?
Vertical output IC shorted. Replace it. Before replacing it, check all the associated components connected to its terminals for failure; especially for any zener diodes for short. It is most possible case. Refer its circuit digram [schematic diagram] for more details.
Contact any service technician.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 02, 2014 | Televison & Video
Blinking red light
You did not give a model number. If this is an older model Sony, I would be concerned with the audio IC with standby. This IC will be of the TDA-XXXX series. I doubt if you have a problem with power supply. If you can locate the IC mentioned, and read the TDA number, cross reference this in an NTE semi conductor manual. If it does tell you it is an audio IC with standby...replace this IC with the cross reference. Be sure to check any grounds that need resoldered in the same area as the IC mentioned. Thanks for asking and show a few hands of support!
Mar 26, 2011 | Sony Televison & Video
Tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to ...
Tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light position ,please to help of rectivied this problem and send circuit diagram and IC pin configaration thanking you sir
Mar 03, 2011 | Televison & Video
DeawooTV Model DTC 2975 I want to know about vertical ic number.b,cos i can't fine out the number that ic is burn.
Hello
There are two mumbers used in Dawoo tv as vertical IC.
If used is a [9] pin one number is [TDA 8357J].
If used is a [10] pin one, number is [ LA 7848]
OK.
Jan 05, 2011 | Daewoo Televison & Video
Missing vertical deflection on philips TV
TDA 8362B IC which have vertical freq.output is at pin no.43. (vert.osc) caution for fixing this problem minimise brightness to avoid crt burn. proceed as follows 1 if you are getting sawtooth at output of ic tda 8362 pin 43 then check 1 supply at vertical output ic from eht. 2 yoke connector loose . 3 check vertical output ic parts. 4 finally vertical ic. please check for normal output from power supply even though fault gets rectified just for protection. good luck.
Sep 22, 2007 | RCA 13R400TD 13" TV
Philips Magnavox 27MS343S 27" TV Logo
110 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
