Question about Kenmore Refrigerators
Ice maker We have a Kenmore Cold Spot side by side model number 106.56586501 the ice maker has frozen up at the nozzel that comes in through the back of the freezer. How can we fix this?
SOURCE: kenmore coldspot fride problem
The water line could be frozen. Take a hair dryer and heat up the tube where the water enters the ice maker. MAke sure it doesn't get to hot and start melting the plastic,
Posted on Feb 02, 2008
  • 943 Answers
hi thanks for the question if the ice cubes are formed in the tray nicely then you need a new ice maker if the whole ice tray is a smooth sheet of ice the freezer might not be cold enough empty out the ice manually ant try again &lower the freezer temp thanke the appliance doc
Posted on Sep 17, 2008
  • 370 Answers
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Posted on Nov 20, 2008
  • 531 Answers
SOURCE: Ice maker stopped working???
water valve or icemaker or make sure freezer is freezing check see if you have frost build up
Posted on Apr 07, 2009
  • 2237 Answers
SOURCE: 2000 Amana BX21Vl fridge: ice maker and freezer not working.
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of. after the freezer freezes again, your ice maker will work again.
Posted on Aug 28, 2009
Why does my refrigerator keep acting up the freezer gets frosted up then the frig gets warm I have cleaned it underneath unplugged it for 24 hours then plugged it back in it works great for about a w
This problem can have many causes, but generally it is a defrost issue. If the freezer coils are frozen over, they block cold air flow to the refrigerator; and can be caused by different part failures. See the link below for a good explanation of possible failures and for parts. Also, if you turn the refrigerator temp to 0ff and unplug the refrigerator then plug it back in, it should go into defrost mode. Leave it that way for 15 or 20 minutes, then unplug and plug it back in. It may resolve the defrost mode problem. If not you'll need a part, or repair man. Kenmore Refrigerator Freezer is Cold But Refrigerator is Warm
Oct 18, 2014 | Kenmore Refrigerators
My kenmore side by side is not producing ice and there is a red light blinking inside the freezer sec
Can you locate your model number inside the fresh food section around door frame? I believe you have the ice maker with the electronic eye and sounds like you need to follow these instructions so the ice maker works again. If I am wrong then please correct me by posting your model number that should look like this example=> 321.234567 Click Here=> Whirlpool Ice Maker Infrared Electronic Eye Technical Information I am here if you need to ask questions, Sea Breeze
Nov 30, 2013 | Kenmore Side by Side Refrigerator
No ice is being made.
Most likely either water valve is bad or ice maker is bad. You would need to determine if Ice Maker is sending voltage to water valve. If it is, replace valve. If it's not, replace ice maker. Also be sure filler tube going through back wall is not frozen. If it is, replace water valve.
Sep 02, 2017 | Kenmore 22.0 cu. ft. Side-By-Side...
I have a Jenn-aire JSD2695KES - it is a side by side, a couple of years old with an ice maker. Ice gets jammed in the last ice spot in my ice maker. It has been getting stuck in other spots lately, too,...
That sounds like a frozen over water fill tube due to a leaking water control valve. You may need to pull the ice maker out to see it but what you described is what happens when this happens. If frozen over the water will still come out on some models because there is a split in the top of the fill tube. Or something needs corrected on the amount of water time is OK for your ice maker. let me see if I can find the service manual for your model Be back soon Sea Breeze
Sep 21, 2009 | Refrigerators
Stopped making Ice cubes on S/S kenmore refrig. water nnot flowing in tube that runs up the back
This problem is the dual water control valve coil for that side. If you fill the ice maker with tap water and it cycles then the problem is most likely the dual water control valve on the rear and near the floor. Also make sure that the fill tube inside back of ice maker is not frozen over. Let me know the model number and I can tell you the part number for the replacement, Kenmore model numbers look like this for example 213.256489 Thanks, Sea Breeze
Aug 15, 2009 | Kenmore Refrigerators
Not producing ice
There are several possibilities. The dual water control valve is defective going to the ice maker, defective ice maker thermostat; frozen water fill tube leading to the ice maker is blocked with ice. You can see if ice maker is working by filling it with tap water and waiting to see if it dumps. If it does not empty the icemaker of the ice I would think ice maker thermostat. If it dumps ice and does not refill I would say you need a new dual water control valve. Sears has a complete model number system that is confusing I know. Sears made it that way. Not sure why but look around the cold food door while open and look near bottom on the frame just above the kick plate. The number looks like this, (model No. 253.64802400 for example) I will need that number to help you solve the sound alert coming from your refrigerator. Find that number and we can go from there, Thanks, Sea Breeze
Jun 15, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 18, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Apr 06, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore Refrigerator Ice Maker
it sounds like your inlet water valve is not closing all the way,pull frig out turn water off,remove valve get model number from inside the frig. and replace it,let me know-mike
Jul 07, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
54 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
