Home | T-Mobile | Wing? Smartphone | Hi! I bought a new
T-Mobile Wing? Smartphone
Problem for T-Mobile Wing? Smartphone
Hi! I bought a new
By acro27 on Oct 28, 2009
Hi! I bought a new T-mobile wing for my brother from ebay but when we try to open the internet explorer it says "iexplore is not a valid pocket pc application" and also when I try to open help it says "peghelp is not a valid pocket pc application" I downloaded Opera to use the internet meanwhile but is a new phone and it should be working ok. I talked to the seller but the say that I will need to send the equipment back to them but I live in Panama so I need to cover the costs but they're almost 100.00 dollars. Do you have any idea about how to get a solution to use the ineternet explorer and help?
Comments:
Oct 28, 2009
- Thanks for your quick answer. I already tried both steps but these didn't worked. I will appreciate if you have something else.
Solution #1
posted on Oct 28, 2009
Not Rated)
sardanadixit
Rank: Wiz
Rating: 82%, 278 votes
Try hard resetting your device by:
NOTE: It will remove all the data from your phone and restore it to factory settings.
Take out the memory card if inserted and then press and hold the left SOFT KEY and the right SOFT KEY, and at the same time, use the stylus to press the RESET button at the middle left side of your device
Release the stylus, but continue pressing the two SOFT KEYs (the soft keys are two buttons with a "-" symbol on them) until you see the following message on the screen:
“This operation will delete all your personal data, and reset all settings to manufacturer default. Press Send to restore manufacturer default, or press other keys to cancel”
Release the two SOFT KEYs, and then press the button green phone button on your device.
BUT the easier way is to use the Clear Storage to clear the device storage and reset all setings back to factory default settings. You will lose all your data and files on the device storage when you use Clear Storage, so make sure to do a backup first if you need it.
1. Tap Start > Settings > System tab > Clear Storage.
2. Enter “1234” then tap Yes.
Comments:
Oct 28, 2009
- In this case, you will need to flash your mobile.
Note: Flashing is fun but a dangerous procedure, so you should read all the instructions carefully else you will end up in bricking your phone. Read the guides here:
http://forum.xda-developers.com/showthread.php?t=369397
The above webpage has complete instructions on how to flash your mobile phone.
Solution #2
posted on Nov 14, 2009
Not Rated)
rain_catcher
Rank: Wiz  Phones & Accessories  Expert
Rating: 77%, 50 votes
ok if its t-mobile and your a t-mobile customer call them and have them walk you thru the setup of your internet connection.
Popular Solutions for T-Mobile Wing? Smartphone
Questions and Unsolved Problems for T-Mobile Wing? Smartphone
Do you recommend T-Mobile Wing? Smartphone?
Answer
Answer
Whay can't I get my favs? Latest Rom Ver. on my cell is 5.4.405.1 and the latest ver.out is 4.26.... (More)
Answer
i have put a code on my phone and now it is not opening
Answer
i have a t-mobile wing which has been deactivated.when it gets turned on it goes strait to a unlock... (More)
Answer
i have a tmobile modem and want to remove the content lock how do i do this , i have tried putting... (More)
Answer
how do you remove t mobile content lock without credit card online
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For T-Mobile Wing? Smartphone:
Top PDA Experts
Rank: Guru Guru
Solutions: 554
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more PDA Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
