Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Ge xl44 sometimes oven gets to temp sometimes no broiler works fine
  • 2 more comments
  • Anonymous Jan 02, 2008
    broiler works fine but oven wont come up to temp.
  • georgeboy Jan 04, 2008
    the problem was fixed with a new ignitor for the oven portion of the unit a 68$ item a few screws and 2 wire nuts to fix. the oven reachess temperature in a matter of minutes now.it is impossible to tell if the part is malfunctioning and the only way to tell is by changing it.i believe that the part breaks down from the high heat of the self cleaning use ,which i will never use again
    my problem was fixed with a new ignitor a few screws and 2 wire nuts a very easy fix but a 68$ part
  • daleeb Jan 05, 2008
    Broiler dosn't work, I wonder if any one knows the part # for the broiler igniter?
GE XL44... Oven does not work. It was working just fine one day & then would not work. Everything else works fine. Stove has electric ignitiion. Could it be it is not working on the oven? Any ideas?
Posted on Jan 03, 2008
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: I have a GE xl44 Gas stove. Oven will light, but
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Oct 03, 2010
I have a Kenmore Elite oven. The upper oven doesn't maintain temp setting. Eg, if I set baking temp at 375, oven may get to that temp but a few minutes later, it's at 325 or less. Broiler works fine.
im taking that it,s gas....do you smell gas at anytime? sounds like you migh have a light gas leak if it,s gas...also how old is this oven?
Aug 13, 2016 | Kenmore Ovens
I have a 30 inch Frigidaire self cleaning oven. The oven will no longer heat up in a normal amount of time using the bake function. Sometimes I can smell gas when using bake. It cant reach the desired...
Sorry to read about your problem, I hope this helps you out.
Bad gas control valve or oven temp control
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Top broiler element works sometimes but not often
Sounds like an iffy clock control. You could try replacing it, but it ain't cheap.
May 21, 2010 | Whirlpool RF364 Electric Kitchen Range
Temp control
No adjustment. Could be bad temp control unit or bad oven temp sensor. You would have to purchase a repair manual and test the current flow to and from the circuit. And then testing the oven temp unit with multi-tester.
Jul 23, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Burners and broiler work, but oven doesn't
If the broiler is working then the element is good. The T-stat controls the oven temp. Have you checked it?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 03, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Oven not working. Top, broiler, and warmer are working.
Have you checked for proper gas flow into the over or broiler? This is a gas valve back there that will sometimes go bad. Also there is a sensor near your knobs, it is a timer that will go bad, the valve is about 85 dollars and the timer is about 65 dollars
Feb 08, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore gas range model# 362.72321 Oven will not ignite (sometimes)
Range Oven Temperature Sensor Part Number WB20K0004 Sears PartsDirect
This will be why the oven acts up. The broiler doesn't rely as much on this as the bake part does. Replace this and it should fix your problem.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Jun 14, 2017 | Ovens
Sf195lehz5 free standing gas oven,
Check both gas valve solonoids for 216 ohms [blue broiler wire to the orange common and red oven wire to orange common] both must be ok.
Check oven temp sensor for 1080 ohms.
If above are ok then the problem is either the spark module or the control board.
Since the gas valve was not opening and there was not ignitor sound I replaced the spark module for about $90. You have a 50-50 chance of being right.
My range is relitively new and I'm haveing an oven light problem which I traced to the control board so I may replaced this board to for about $200.
HS
Oct 05, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Oven doesn't heat
sounds like you have a bad oven ignitor, although oyu see it glowing orange its not hot enought hoopen the gas valve, very common occorance. 2 maybe 4 screws and 2 wires, order aand replace the bake ignitor
Mar 26, 2008 | Kitchen Ranges
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
755 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
