Question about Dryers
DRYER WILL NOT HEAT!!! HELP!!!/Kenmore HE3 Dryer-Mod.# 82822102
Every thing works except the heat. I just fixed the washer from advice I rec. from your site and now the dryer is out. We took the dryer apart and cleaned out the lint. There was a lot! I dont have a ohm. thing and I don't know where to get one. Please help!!!! any suggestions would be appreciated. thanks lost mother of 3...
  • 1 more comment
  • 199105 Jan 02, 2008
    LOL SORRY! IT WAS TOO LATE WHEN I REALIZED I ONLY PUT IT ON THE HEADER. ITS A KENMORE ELITE HE3 MODEL # 82822102. I DID TRY THE BREAKER AND STARTED THE DRYER AGAIN AND NO LUCK. IF YOU HAVE ANY OTHER IDEALS PLEASE LET ME KNOW.. THANK YOU FOR YOUR TIME.
    S.L.
  • Anonymous Jan 14, 2008
    only air!! no heat!!!
  • Anonymous Mar 07, 2008
    You need to replace the circuit breaker. The do wear out and do not allow the full 220 to run through them. This happened twice at my old house. The heater would not heat so we replaced it and the the dryer would not dry. My neighbor was a retired electrician and replaced the circuit breaker on the first on and then I did on the second one
    Problem Solver:
  • 11 Answers
Kenmore Elite Quiet Pack 2 - won't heat. any suggestions
Posted on Aug 04, 2009
    President:
  • 1,314 Answers
First its always important that you give make and model as different makes have different repair proceders for repair the easyiest thing to do first trust me is to turn the breaker off then on then try drier and let me know what you found now dont rate me till we are done ok
Posted on Jan 02, 2008
  • robert samples Jan 02, 2008
    oh i know how to fixem but its late here so we will start tommrow you can get a decent ohem meater at a decent price at radio shack or lowes you just need an analog or digital meter ask for one that has the longest metel tips on the leads and ill teach ya how to use it
    e mail me me at b4829 @yahoo.com i need to send you an image
My dryer will not heat at all to dry my clothes
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 02, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My kenmore elite he3 dryer has quit heating could it be the heating element and if so where can i find it on the dryer? The model # is 110.82822103 and the serial# is MR1751757
heatman101
Jun 05, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
My Kenmore Elite (Whirlpool) HE3 elctric dryer is no
A dryer not heating usually means that either the heating element is burned/broken (open circuit); a thermal fuse in line with the heating element is blown or; a thermostat is faulty.
Dryer needs to be partially disassembled to diagnose with a multimeter.
Charlie
Sep 29, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Dryer working but no heat
The manual says that two circuit breakers used,and that the dryer
can spin but no heat if one of them tripped, check your panel and see
if any breakers are tripped. If this was the problem,have an electrician
check the circuit.
Apr 09, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Dryer will not heat
Have a certified electrician check your outlet. The dryer requires 220VAC for the heating elements to work. If this is ok, check the heating elements it may be broken.If this is ok, check the high and low limit switches, this could be defective.
Apr 04, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Dryer runs, no heat
hey mark we got this one done.if your ignitor is glowing and its not firing over 2 things flame sensor,but rarley.99 out of 100 will be the valve coils 2 black guys on top of the gas valve with wires going to them.you could use the cheapest brand you can find[ie..frigadire,ge,kenmore,amana.there all the same .on my truck i stocked frigadire because it was cheaper for me and then would make more profit yet charging same price as there brand,you can do it .God bless,tom
Dec 28, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore elite he3 dryer
take the bottom panel off the washer it is held in by two or three screws the heating element is off to the right
Dec 20, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Dryer not heating he3 kenmore elite
repl/ thermal fuse if no heat if heating for a little while clean exhaust, and repl/ coils
No heat
REMOVE THE BOTTOM PANEL SHOULD BE 2 SCREWS HOLDING INSPECT IGNITOR IF HAS SMALL BURN MARK REPL,, IF NOT THEN REPL, THERMAL FUSE THAT WILL FIX THAT
Nov 29, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore he3 not heating
REMOVE 2 SCREWS ON BOTTOM OF PANEL,, REMOVE LINT SCREEN , NOW REMOVE BLACK METAL HOUING ,,,DISCONNCT POWER BEHIND METAL HOUSING THERMAL FUSE IS RIGHT THERE REPL ,NOW SHOULD HEAT UP ,,,2 RED WIRES CONNECT TO IT
Nov 23, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Dryers Logo
205 people viewed this question
Top Dryers Experts
