Happy New Year everyone!
I am considering replacing an old Sony 35" Trinitron with a new LCD HDTV. The center Lifestyle 12 cub sites on top of the set today, and the left/right cubes are on stands. I have serious space constraints (this is in a corner and not along a wall) and I can't figure out how to place or attach the Lifestyle cubes on top of the LCD HDTV. I do not want to replace the Lifestyle 12 as it works fine.
Any solutions on how to attach the speakers to the new LCD HDTV?
Thanks!
Mount to wall, brackets available to purcahse on loads of on line sites. and from bose direct cost 5 dolurs to 50 dollars eack depending how fancy you want to be.
would recomment also distancing the left right satellites as you will be amazed how much improvement in sound is gained from a well defined centre channel.
also if you want to be really smart. its really not necessary to see the centre satelliet and it could simply sit of the stand behind the tv. with no problem. plus you could use the tv audio input to make the tv as a centre channel. you would be surprised how well that works. make sure you disable the tvs steroe function or your surround sound will not sound too surround....
finally if you have lifestyle series II make sure you conect the 5.1 input to the bass box to your tv. and get rid of the bose cd player , put it out of sight, and loose the remote. will work even better than it did before !
I have a Bose Lifestyle 12 which is 11 years old. I just bought a 42" Panasonic plasma tv. How do I hook up the Bose system for HDTV. It doesn't have the HDcable.
