Question about Toshiba TP55G60 55" Rear Projection Television
SCREEN BROKEN I need to replace the plastic screen, I have some number that maybe are the part numbre here they are: DT97E78-6.2 23837481-55L 04556PMMA If you can let me know where to buy this part, because I went through the internet in tvparts.com and I can't find it. That's the only problem with my TV, everything else is in perfect condition. Thanks. Jorge
  • mandychavez1 Nov 21, 2008
    cracked screen on the toshiba tp55g60 tv
Did you ever find a screen for your Toshiba?? I need one also. Thanks
Posted on Jan 03, 2008
I want to have the screen stay on longer than 15 seconds
Go to settings - Display - Screen timeout - increase from 10 secs
(Since you didn't provided the model number of your phone , this is the basic setting that will work in any mobile phones )
For precise help let me know your cell's model numbr
Sep 16, 2016 | Alcatel Cell Phones
How do I fix my Laptop's screen?
If it is physically broken, it must be replaced. You may have to dissemble the top cover to get a part number to order a replacement. There are often some screws under removable plastic or rubber covers. Then the front bezel must be gently pried around the perimeter to release the plastic clips that hod it in place.
If you look at it in a bright light, and see that the LCD is still working, the inverter for the back light may have failed.
You should be able to connect an external monitor to confirm that the remainder of the laptop is still working well.
May 06, 2016 | Computers & Internet
My Bernina Artista 170 Sewing Machine Touch Screen is not responding, Touch Screen just not working, Touch Screen is maybe cracked, can it be replaced ?
Maybe Cracked screen???
If broken, the screen is just like cellphone screen, digitizer is also broken and screen won't respond to screen touches... Find a trained repair shop. EmbroideryServices
Apr 20, 2014 | Bernina Artista 170
The 17.1' display of my toshiba satellite P105 its broken, two white lines blocked de screen, and 1 half of de screen its blocked by blacki need the part number or de model of de display for replace my...
Just a quick note, before you go replace the entire screen, make sure it's not just a wiring problem. If so, it doesn't cost as much to replace the wires connecting the screen to the laptop. LCD's are much more expensive!
As for replacing the display, this website has information on the display, along with the ability to purchase it from their site. http://www.pelltechnology.com/Toshiba/Laptop/Toshiba-Portables-Satellite-P105-Series-S6024/Toshiba-Satellite-P105-S6024-LCD-Screen-Replacement-P350475.asp
Hope this works!
Apr 11, 2011 | Toshiba Satellite A105 Notebook
The plastic screen isn't broken, but when I turn it on, it appears as broken.
if there are no visible marks or cracks on the plastic case itself then it sounds like the LCD screen behind the plastic protective screen is cracked or damaged (especially if its been dropped, or had a lot of pressure put on it e.g. left in a pocket when sitting down, heavy object on it), if its new i would consider taking it back with the receipt for a replacement.
otherwise it will need someone with some repair skills to replace the screen.
Aug 06, 2010 | SanDisk Sansa e250 MP3 Player
Projection tv screen broken
Fixya is unable to source replacement dinosaur screens.
Dec 30, 2017 | Toshiba Televison & Video
Maytag LDG612 Lint Screen Sleeve broken
See the goodies for the only individual manual I have seen online, which helps explain that you get to pop the lid then the front off the thing, requiring
  • disconnecting power,
  • common screwdrivers, your choice of power and flexibility
  • putty knives (to pop the top off, and thence the front)
  • shop or utility vacuum with cheap (easy to clean!) brushes/nozzles
  • get-go and working space
  • mind the gas connection
  • maybe spare assembly screws and some patience to line up old heat-hardened parts
  • maybe RTV or silicone to help the reassembled stuff get tight on its own, rather than on pain of breaking more brittle plastic
From there you just unscrew it, replace the part and reassemble with care, energize, test and go dancing.
Jan 03, 2010 | Maytag Dryers
Digital camera screen broken
A cracked screen will cost you, but maybe not as much as you think. Instead of replacing the whole , you can spend about $300 and replace the screen yourself. All you need is a small screwdriver.
1)Turn off the power to your screen and unplug all cables connected to it.
2)Remove the battery, if one is installed.
3)Locate the covered screws around the cracked screen. Remove the rubber/plastic covers, then unscrew the screws.
4)Gently remove the plastic frame around the cracked screen and set it aside.
5)Disconnect any power cords or cables going into the LCD screen.
6)Remove the cracked screen and slide the new screen into place. Replace any tape or plastic fasteners that hold it in place.
7)Reconnect all internal cords to the screen.
8)Screw in the frame and replace all the screw covers.
9)Reconnect the power supply and all external cables to the LCD screen and switch it on.
Aug 31, 2009 | Sony Cyber-Shot DSC-P150 Digital Camera
Broken ts
yes you can take the glass out but leave the plastic that protects the screen. but remember your touch screen wont work if the glass is not replaced which can be a bit expensive
Dec 23, 2008 | HP Pavilion TX1000Z 12.1" Touch Screen...
SGH-S400i
hi there mate
a puk number can not be verified as every puk number is different you puk number can only be verified by your service provider as everyones is different hope this helps an please if you have time can you please rate me
thanks again
Feb 19, 2008 | Samsung SGH-D500 Cellular Phone
Televison & Video Logo
115 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
