Brother MFC-420CN All-In-One InkJet Printer
Wireless printing problems
shared by 2 users
posted by ze2000 on Jan 02, 2008
I can't print wirelessly and i don't know why. I used to be able to, but for some unknown reason it stopped.
i also cannot print when it is hooked up via usb connection.
Thank you for your help.
tim
tnisly@sbcglobal.net
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Posted by xrayman2351 on Jan 03, 2008
i am unable to print ms office docs and adobe files but test prints work just fine over wireless. printer monitor comes up quickly then says "printed" and goes blank. at first this problem was unique to adobe then all of the sudden it started with ms office docs.
Solution #1
posted on Jan 02, 2008
Not Rated (0)
bigdaddy67
Rank:Master Master
Rating: 88%, 50 votes
More than likely the problem is with your router and not the machine. First make sure your IP address is correct.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on wireless printing problems:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Mix-it-up
Rank:Guru Guru
Rating: 88%, 1136 votes
I dont believe that you have done a wireless printing before. Or do you run another modell as the shown MFC420CN?
In case you mean you have printed wirelessly through a wireless router, you have to check the network connection:
Have a look around here:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=mfc420cn_us
If you try to print/scan/fax by USB instead of useing the network make sure that the USB drivers are installed properly (either network OR Usb ;-))
Thank You!
Can you Help with these Printers problems?
my printer will not print a good picture
Icahnged the tellow cartridge because it showed to be...
It printed 4 pages just great then the error message...
mirrowed print
I have been to many sites that say they answer it but they...
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Help us help you.
Take a brief survey and help us improve the site.
Your opinion counts!
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
