Did you take the derailer off? Or is it that you can't get the wheel back in through the derailer?You should be able to take the wheel off without doing anything to the derailer except when you have to sort of push it forward to allow the axle to drop inDid you take the derailer off? Or is it that you can't get the wheel back in through the derailer?You should be able to take the wheel off without doing anything to the derailer except when you have to sort of push it forward to allow the axle to drop in
You can't post conmments that contain an email address.
1st The brakes: Once you have ran the cable through appropriate cable holders and to the brakes-you hold the brake calipers shut-remove excess slack from cable by pulling on it with pliers and back off a little before tightening the nut holding the cable(amount you have to back off tension depends on how strait your wheel is).
The Front Derailer doesn't usually have adjustment so you put the gear lever in top gear-loosen the nut holding the cable-push the derailer into the right position-remove slack from cable with pliers then tighten the nut.
The Rear Derailer: will need to be done the same way if your running a new cable..*But there is a screw on the derailer near the junction of the 2 parts that adjusts the position of the derailer- so you can do minor adjustments-**NOTE-there are 2 screws- 1 changes the position in or out and the other changes the angle**
Use this link for instructions.It is best if you have your bike on a bike stand. If you don't have a bike stand then you can put it upside down with a towel under it. Make sure that none of the wires are being pinched while either in the stand or while upside down. http://www.parktool.com/blog/repair-help/rear-derailler-adjustments-derailleur
first disconect cable from derailer and determin if its the derailer or the cable. if its the cable take it off coil it up put it in a can with wd40 or other penatrating oil . if its the derailer take the chain off and work it free by hand keep putting oil on it while you work it back and forth
single speed bikes have a single ratchet or fixed sprocket with no offset of the spokes, so you would probable need another rear wheel.
Another derailleur is probably simpler, try ebay
You may have a locked up wheel bearing or you may have an object stuck in the chain. Can you spin rear wheel by hand? If not, most like bearings, if so, then you may have bent gear tooth or something stuck in chain. Check derailer to make sure it is not bent
Forget new guide wheels. A new rear derailer is the real fix. You will need to order a new one by the number of gears on the rear gear cluster. How the derailer is mounted, Which way it moves when by the spring direction etc... By the way, get a higher quality one than the one you have got. If you go megawheel on the lower guide wheel; which I recommend, you might need a couple more segments in your chain. Yes, you need a new chain. If you wore out a part on you derailer, your chain is getting old. I recently bought a new rear derailure for my wife's bike for 29 bucks at a much better quality than the old one. It does not have problems of getting between gears, clicking etc... like the old one did new.
