i got the linksys router problem which no problem at all when i connected to sg broad band . currently use it to connect to malaysia streamys broad band and problem occured. when i connect the router to modem and my computer, all the light on mode and router appear to be good. But my computer shows able to connect the router but not the internet. if my computer connect to the modem straight everything is fine and able to connect to internet. from my understanding there is no need for the router driver to install for the router to work. so far my computer is without route driver. when i enter 192.168.1.1 on browser to enter router setup page, everthing seem to be fine and at factory settings.
You are able to access the 192.168.1.1 router page. In the top right hand corner you will find Status TAB. On this tab do you internet IP address. If you do not hane Internet IP address, then the router is not set up properly. Check the settings of the router. If necessary then upgrade the firmware of the router. Click here for step by step solution
The problem should be the settings are still lock on the previous ISP. You can try to release the connection then reconnect to get the right settings for the later ISP setting.
Or you should set the settings manually, IP address, DNS number, gateway, DHCP enabled.
For that you enter in linksys configuration page with 192.68.1.1 then enable dhcp . Aso set WAN settings as your internet service provider settings. For that you have to set DNS server and other settings as your malaysia streamys broad band settings. Let me know if you need further assistance. Thanks.
Was this helpful?
Yes
No
Popular Solutions for Linksys Wireless-G Broadband
I have a umw190 modem and despite promises from a Best Buy guy and the wirefly website, my MBR624GU...
(More)
I have a umw190 modem and despite promises from a Best Buy guy and the wirefly website, my MBR624GU Mobile Broadband Wireless Router by Netgear refuses to recognise it! Can you offer any suggestions or do I need to take the router back?
I use cable to router then internet. But the internet always not stay on. I need re-disconnect- and...
(More)
I use cable to router then internet. But the internet always not stay on. I need re-disconnect- and put back on power every 15' minnites to recover the internet. Why? If I use cable to PC without router. the internet has no problem. My router is Belkin 4 port cable/DSL gatewey modle# F5D5231-4 ver.1103 PS: email : zhaoable@yahoo.com
Hi! everything was working just fine, one night my internet connection went down and whenever I try...
(More)
Hi! everything was working just fine, one night my internet connection went down and whenever I try to connect to my wireless network it keeps on saying that I cannot connect because the key's not ok or stgh like that. I hadn't change it!!!!!I tried to connect my internet modem directly to my computer and it works ok, but cannot connect if the cable is connected to my ativa router. I tried to get online to the 192,268.1.1 but it says "Internet Explorer cannot display the webpage" Please help me! It's driving me crazy! Thanks a lot! Lu
