Question about Vacuums
Eureka deep steam cleaner
My deep steam cleaner stopped sucking the water up. any ideas why
  • 1,673 Answers
Re: eureka deep steam cleaner
When these stop picking up water, I assume it is spraying the water out, is because of a missing seal, where the suction port is, or a filter is clogged. Tank isn't set down like it should be.
Posted on Feb 14, 2008
0 characters
3 Points
Is it possible to vacume water with the miele slaris turbo plus?
I wouldn\'t attempt that unless it says you can do that in the manual. Use a steam cleaner. They are made to suck up water.
May 18, 2014 | Bissell Carpet Cleaner Powerbrush Deep...
What cause it to stop sucking up the water?
has anyone or figured it out yet I just bought one and the suction wont work at all not from bottom or the attachment part heat works solutions works no suction at all help!!!please email me at
Jan 17, 2012 | Bissell ProHeat Turbo Deep Cleaner Upright...
My steam cleaner is not sucking up the water. What are possible things I can do to troubleshoot?
inside the water container there is a red flap that has a filter, clean it off and you are good to go
Jun 14, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Steam Cleaner
my cleaner is not spraying or sucking up the water?
May 10, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Suds not coming out
do you have the dial set to presoak ? Clean? or Rinse?
make sure the container for the soap is full and is popped into place correctly.
also... if the water canister is empty or the dirty water container is full it will stop sucking up the water :)
Mar 29, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Doesn't return the dirty water to the tank, after apply the water
My Bissel has been having problems sucking the dirty water back into the tank. It's like it works for half a dozen uses and then just stops working. After I turn it on and off for a couple of hours trying to troubleshoot the issues it just starts working out of the blue again and sucks up the dirty water. I know there is a yellow stopper that goes up and can stop the flow but that's down and not the issue here.
Sep 21, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Eureka Atlantis 2590 Deep Steam Extractor will not spray
I cannot find a shampoo canister for my Eureka 2590 Series extractor. They are not made anymore.
Jun 07, 2009 | Eureka Atlantis 2590A Wet/Dry Vacuum
Leakage from eureka deep steam carpet claeaner
You will just have to take it apart to see if a hose is loose, came off, or is cracked.
Jun 14, 2008 | Eureka 2576A Steam Vacuum
Vacuums Logo
308 people viewed this question
Top Vacuums Experts
Roger Potts
Are you a Vacuum Expert? Answer questions, earn points and help others
