Sony PlayStation Portable  Slim  Console
Problem for Sony PlayStation Portable (PSP) Slim (PSP-2000) Console
How can i open the recovery menu of my psp 2000
By mmendoz45 on Oct 28, 2009
how can i open the recovery menu of my psp 2000 v6.10.iv tryd pressing the R & the power it didnt go to the reovery menu. pls help...
Best Solution
posted on Oct 28, 2009
Helpful)
pradeep1985
Rank: Master
Rating: 80%, 65 votes
The recovery menu does not work with official firmware, and you've replaced your custom firmware with genuine firmware. You'd need to use Pandora to reinstall custom firmware..
plz ;eave your feedback....thank you.
Comments:
Oct 30, 2009
- Guide Showing How to Create the Perfect Pandora Battery
This guide will take you through the steps needed to create a perfect universal Pandora’s battery
You can follow this same guide on both the Classic and Slim PSP
Introduction
This guide is a rewrite of Moose_Island’s guide, as it started to become outdated.
This will guide you through the steps of creating a “perfect” Pandora battery and memory stick, with all the features you may want.
After following this complete guide, you will be able to use your Pandora battery and memory stick to both boot your PSP normally, but also use TimeMachine, 3.90 M33-3 installation, NANDTool and many more things.
Please take a look at the compatible batteries list under this spoiler to make sure that you’ll be able to follow this guide.
Battery Compatibility List:
Working
* Sony “standard” Li-ion 1800 mAh.
* Sony PSP-280 2200mAh.
* Datel, PSP Battery 3600 mAh (X2).
* Datel, PSP Battery 1800 Max Power.
* Datel, PSP Battery GO MAX (Model # GM1000, uses AAA batteries).
o Note: If you remove the AAA batteries, it resets the serial.
Not Working
* 3.6v 3600 mAh Battery Pack (Silver letters) (Model PSP-360)
* 2600 mAh Mega Battery Pack
* Atomic Battery Pack 3.6V 1800mAh
* Sony PSP Bloc-Battery pack 3.6v 1800 mAh
* Battery 3600mAh, unknown brand, (china made model NK-RH008)
* Battery Pack, unknown brand, (lithium) 3.6v 3600 mAH
* Intec 1800 mAh Li-ion
* Intec 2200 mAh
* UltraLast e-Boost 3.7v 2200mAh Li-PO battery
What will I need?
First we need to go over what you need to create a Pandora’s battery:
* A PSP with a custom firmware, or homebrew compatible firmware.
* A PSP battery you are willing to convert
o A classic PSP battery will fit in both PSP’s, a Slim battery only in the Slim.
* A USB cable.
All the specific files are inside the different parts to keep it clean.
Part 1: PreparationDownloads: Hellcat's Pandora Installer Revision 4 (444)
1. Important: Before you continue, backup all files on your memory stick, you will lose them.
2. Download the above file and extract it to your dekstop.
3. Enter the ‘pan3xxr3a’ folder, then copy the ‘pan3xx’ folder to X:/PSP/GAME.
4. Launch the installer from GAME > Memory Stick.
5. Press circle to make your battery a Pandora.
6. Press R + X, then L + R + X, to format your memory stick.
7. Press X to turn your PSP off.
8. Enable USB again, and copy your backup back to your memory stick.
Note: From now own your battery is a Pandora, but won’t be able to boot from the NAND yet, therefor, you’ll have to use only your AC adapter for the rest of this guide.
Part 2: Installing TimeMachineDownloads: TimeMachine (191)
1. Download the above file and extract it to your desktop.
2. Enable USB on your PSP and browse to X:/PSP/GAME/.
3. Copy the ‘TIMEMACHINE’ folder (from your desktop) into ‘X:/PSP/GAME/’.
4. Toggle off USB, and browse to the Game > Memory stick on your PSP.
5. Launch the TimeMachine Installer.
6. Choose ‘Install iplloader on PSP MS boot sector’
7. You’ve now got TimeMachine, now follow the guides under this spoiler to add firmwares to it.
Adding firmwares to TimeMachine:
Classic PSP only
Installing 1.50 to the memory stick Downloads: 1.50 EBOOT (251)
This will allow you to run 1.50 from the memory stick.
1. Download the 1.50 EBOOT.PBP and rename it to ‘150.PBP’.
2. Place the newly renamed 150.PBP in root of memory stick.
3. Run the TimeMachine Installer and select the option which is ‘Install 1.50 (PHAT)’.
4. Continue to another option or exit.
Installing 3.40 OE to the memory stickDownloads: 1.50 EBOOT (251), 3.40 EBOOT (153)
This will allow you to run 3.40 OE from the memory stick.
1. Download the 1.50 EBOOT.PBP and rename to ‘150.PBP’.
3. Download the 3.40 EBOOT.PBP and rename to ‘340.PBP’.
4. Place the newly renamed 340.PBP in root of memory stick.
5. Run the TimeMachine Installer and select the option which is ‘Install 3.40 OE (PHAT)’.
6. Continue to another option or exit.
Slim PSP Only
Install 3.60M33 to the memory stickThis will allow you to run 3.60 M33 from the memory stick.
1. First you must dump the 360.PSAR from a PSP Slim running 3.60M33:
1. Run the program 360DUMPER that is found in the TimeMachine Files on a psp running 3.60 M33.
2. The PSAR can be checked against these MD5 and Size checks to make sure it is useable:
* Size: 18189502 bytes.
* MD5: EAA13343C70D9B0337C75B295 474C69A
2. Once done, place the 360.PSAR in the root of your memory stick.
3. Run the TimeMachine Installer and select the option which is ‘Install 3.60M33 (SLIM)’.
Both PSP’s
Installing 1.50 with 3.40 HW modules to the memory stickDownloads: 1.50 EBOOT (251), 3.40 EBOOT (153)
This will allow you to run 1.50 on the Slim.
1. Download both 1.50 EBOOT.PBP and 3.40 EBOOT.PBP from above.
2. Rename them from 1.50 EBOOT.PBP -> 150.PBP and 3.40 EBOOT.PBP -> 340.PBP.
3. Place both of the newly renamed eboot’s in the root of your memory stick.
4. You will need the 3.60 PSAR file which can only be obtained by the following method:
5. Once done, place the 360.PSAR in the root of your memory stick.
6. Run the TimeMachine Installer and select the option which is ‘Installing 1.50 with 3.40 HW modules (PHAT & SLIM)’.
Part 3: Installing DDCv5Downloads: Despertar del Cementrio v5 (74)3.90 EBOOT (85), 1.50 EBOOT (251), 3.40 EBOOT (153)
1. Extract the downloaded ‘dc5.rar’ to your dekstop.
2. Copy the ‘dc5′ folder to ‘X:/PSP/GAME/’.
3. Rename the downloaded EBOOT.PBP’s to:
* 1.50 EBOOT -> 150.PBP
* 3.40 EBOOT -> 340.PBP
* 3.90 EBOOT -> 390.PBP
4. Copy the renamed EBOOT’s to the root of your memory stick.
5. If you didn’t install TimeMachine the last step, follow these 2 steps first:
* Create a folder called ‘TM’ on the root of your memory stick.
* Create a file called ‘config.txt’ in the TM folder, leave it blank.
6. Launch the installer from GAME > Memory stick.
7. Press cross to start the installation.
8. You will be asked to hold what button you want to use for loading DDCv5 on boot later, do so.
9. Wait for it to finish, and you’re done.
Oct 30, 2009
Part 4: Installing ELF menu and the USB FilesDownloads: Jas0nuk’s ELF Menu (57), RSPsar Dumper v3.2 (56), 1.50 EBOOT (251)
* Extract the ‘RSPsar Dumper v3.2.rar’ to your desktop.
* Place the folder named ‘RS’ in the root of your memory stick.
* Rename the 1.50 EBOOT.PBP to ‘EBOOT.PBP’.
* Place ‘EBOOT.PBP’ in the root of your memory stick (’X:/’).
* Create a folder called ‘elf’ in the root of your memory stick.
* Create a folder called ‘kd’ in the root of your memory stick.
* Place the folder named ‘RSPsarDumper’ in ‘X:/PSP/GAME/’.
* Run it from GAME > Memory Stick.
* Press square to dump decrypted.
* Toggle USB back on and enter X:/DUMP/F0/kd.
* Copy the following files to the clipboard:
o usb.prx
o usbstor.prx
o usbstormgr.prx
o usbstorms.prx
* Browse to X:/kd and paste the above files there.
* Browse to X:/TM/DC5/kd and copy ‘resurrection.elf’ from there.
* Browse to X:/elf and paste that ‘resurrection.elf’ there, rename it to ‘M33_Installer.elf’.
* Extract the Pandora ELF menu to the desktop.
* Copy the contents of the ‘kd’ folder inside there to X:/TM/DC5/kd.
Part 5: Finishing off
You can remove all files used in this guide, except these:
* X:/TM/
* X:/elf/
* X:/kd/
* X:/390.PBP
There is no point in keeping the other files, this way saves alot of space.
Using your Pandora
* Turn off your PSP fully.
* Remove your memory stick.
* Insert your memory stick.
* Start your PSP whilst holding one of these buttons:
o Cross: 1.50
o Circle: 1.50 modified for Slim support
o Triangle: 3.40 OE
o Square: 3.60 M33
o Button chose DDCv5: DDCv5
o Anything else: Will boot from internal NAND chip (requires 3.90 M33-2 or higher on the Slim)
Note: You can only use the TimeMachine options you actually installed.
Removing Pandora later
* Changing the Battery back to normal:
o Remove your battery and insert the AC Adapter.
o Turn the PSP on.
o Run Hellcat’s Pandora Installer Rev3b.
o Insert your Pandora’s battery.
o Press SQUARE to tunr the battery back to normal.
* Formatting:
o To format on a PSP, go to Settings > System Settings > Format Memory Stick.
CreditsBubbletune – Writing this guide.
Moose – For the old ‘Perfect Pandora’ guide and his help writing this guide.
Dark_AleX – Creating DDCv5 and TimeMachine
jas0nuk – Creating the ELF menu
Hellcat – Creating the 3.xx Pandora Installer
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" ok tnx. can u teach me how o make a pandora bat. & restor it/nx " - mmendoz45
Solution #2
posted on Dec 21, 2009
Not Rated)
ronochu
Rank: Master  Sony Expert
Rating: 80%, 44 votes
If you still confuse with these text guide, it's a better solution out there. I introduce the step by step video guide for you to downgrade your PSP and copy the game to the console. It is used to downgrade any PSP and start downloading games, movie and more immediately! Make sure you follow the guide to make a Pandora Battery first !
Here is the video guide : http://bit.ly/7FCcOc
Was this helpful?
Yes
No
Popular Solutions for Sony PlayStation Portable
Questions and Unsolved Problems for Sony PlayStation Portable
Do you recommend Sony PlayStation Portable (PSP) Slim (PSP-2000) Console?
Answer
Answer
i have a psp firmware model 5.70, how to downgrade firmware?
Answer
when ever i turn on my psp slim it looks like the screen is cracked from the inside. and the battery... (More)
Answer
i bought a second hand psp and it was fine, i didnt play it for a few months now it won't turn on. i... (More)
Answer
i have a new psp 3001 pearl white with the firmware 5.70. what soft ware is avaialble right now to... (More)
Describe your Video Game Consoles problem:
Related Products & Issues:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Video Game... Experts
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
