After cleaning the upper oven I noticed (24hrs later) that the inner glass in the oven door was shattered. Can the glass be replaced? Or will a new door be required?
Thank you
Janet M.
Yes the inner door glass is a replaceable part and the door will have to be disasembled but not replaced. I can help with sourcing any parts for you since you used a premium post.
ill need to entire model # it may be kebs not keb5
Ok based on the breakdown for your oven (single wall oven) It shows 4 glass layers in the door. The outer glass and then 2 inner glass panels they are part #4449251 and costs $50.20 from Marcone (appliance parts retailer) I believe that you need the glass panel closest to the inside of the oven it is part #4449247 and costs exactly the same. It can also be purchased at www3.sears.com just give them the part number i gave you. Thanks again.
The breakdown is confusing, it only shows one oven (at a time) but i double checked the model # and it right so my part#'s are correct.
Yes, if you can help with sourcing that would be great. Thanks very much.
You are right, the Model number is KEBS247DBL4
The serial number is X63501030
The color is black
It is a double wall oven, not single Does that make any difference?
The upper oven has the problem.
Thanks dr.
