Apple iPod nano Second Generation Blue  MP3 Player
Problem for Apple iPod nano Second Generation Blue MP3 Player
My ipod wont turn on or charge
By jessnms701 on Oct 28, 2009
my ipod wont turn on or charge
Solution #1
posted on Nov 09, 2009
Not Rated)
a7878
Rank: Guru
Rating: 89%, 102 votes
Connect the iPod to different computers and let it charge for a while. Also, as it's booting w/ the apple logo, press the menu button to force it to recovery mode. That may let you restore it. If all of that fails on any of the computers, you have a broken logic board. You can try to replace the part yourself, it is available on any auction website. There is an iPod nano Repair service that can fix it for you, but if you're a little tech savy you should use an iPod repair guide that teaches you how to do the repair yourself.
Was this helpful?
Yes
No
Solution #2
posted on Oct 28, 2009
Not Rated)
hawk127311
Rank: Guru
Rating: 90%, 67 votes
If the battery isn't fried you can try the following: I hope this helps and good luck.
Reset To reset your iPod nano (2nd generation):
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2.Press and hold the Menu and Center (Select) buttons simultaneouslyuntil the Apple logo appears, about 6 to 10 seconds. You may need torepeat this step.
  • Tip:
    • Ifyou are having difficulty resetting your iPod, set it on a flatsurface. Make sure the finger pressing the Select button is nottouching any part of the click wheel. Also make sure that you arepressing the Menu button toward the outside of the click wheel, and notnear the center.
    • Ifthe above steps did not work, try connecting iPod to a power adapterand plug the power adapter into an electrical outlet, or connect iPodto your computer. Make sure the computer is turned on and isn't set togo to sleep.
Retry Retry your iPod with a different USB port on your computer, not a USB port on your keyboard or hub.
Restart Restart your computer, and make sure that you have the latest software updates installed. Note:
  • To update your Windows software, select Windows Update from the Tools menu of Internet Explorer.
  • To update your Mac OS software, select Software Update from the Apple menu.
Reinstall
  • To update and reinstall your iPod software, first download the latest version of iTunes.
  • Next, open the new version of iTunes and connect your iPod to your computer.
  • Selectyour iPod in the source list and click "Check for Update" under theSummary tab. iTunes will check to see if your iPod needs to be updatedand perform the update for you.
Restore
  • Note:Because Restore erases all of the songs and files on iPod, make sure toback up any files you've saved on the iPod disk. All of your songs,videos, podcasts, audiobooks, and games can be loaded back to your iPodprovided that you have them stored in your iTunes Library.
How to restore your iPod: For Windows:
  • 1. Make sure you've reinstalled the latest version of iTunes.
  • 2. Open iTunes, and then connect your iPod to your computer.
  • 3.After a few moments, it will appear in the source list in iTunes. Ifthe iPod's display doesn't show "Connected" or "Do not disconnect" youmay need to put the iPod into disk mode to proceed.
  • 4.Select your iPod in the source list and you will see information aboutit appear in the Summary tab of the main iTunes windows.
  • 5.Click the Restore button. You will be prompted with one or more restoreoptions that may prompt iTunes to automatically download of the latestiPod Software. The 4 possible restore options are:
    • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
    • RestoreOption 2: Use Same Version - Restores with same iPod Software versionalready on iPod even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software on your computer.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software on your computer.
  • 6.A progress bar will appear on the computer screen indicating that thefirst stage of the restore process has started. When this stage iscompleted, iTunes will instruct you to leave iPod connected to yourcomputer to complete restore.
  • 7. During thestage 2 of the restore process, the iPod will show an Apple logo aswell as a progress bar at the bottom of the display. It is criticalthat the iPod remains connected to the computer or iPod Power adapterduring this stage. Note: The progress bar may be difficult to see sincethe backlight on the iPod display may be off.
  • 8.After stage 2 of the restore process is complete and the iPod isconnected to the computer, the iTunes Setup Assistant window willappear asking you to name your iPod and choose your syncing preferencessimilar to when you connected your iPod for the first time.
For Mac:
    • RestoreOption 2: Use Same Version - Restores with same iPod Software versionalready on iPod, even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with latest iPod Software version on your computer.
    • Restore Option 4: Restore and Update - Restores with latest iPod Software version on your computer.
  • 6. A message will appear prompting you to enter an administrator's name and password.
  • 7.A progress bar will appear on the computer screen indicating that thefirst stage of the restore process has started. When this stage iscompleted, iTunes will instruct you to leave iPod connected to yourcomputer to complete restore.
  • 8. During the stage2 of the restore process, the iPod will show an Apple logo as well as aprogress bar at the bottom of the display. It is critical that the iPodremains connected to the computer or iPod Power adapter during thisstage. Note: The progress bar may be difficult to see since thebacklight on the iPod display may be off.
  • 9.After stage 2 of the restore process is complete and the iPod isconnected to the computer, the iTunes Setup Assistant window willappear asking you to name your iPod and choose your syncing preferencessimilar to when you connected your iPod for the first time.
Was this helpful?
Yes
No
Popular Solutions for Apple iPod nano Second
Questions and Unsolved Problems for Apple iPod nano Second
Do you recommend Apple iPod nano Second Generation Blue MP3 Player?
Answer
Answer
i connect my iPod to my computer and my itunes or my computer does not recongnizes it. it doesn't... (More)
Answer
why do so many people have ipods. and how do they break.i want people to stop breaking them.i bet a... (More)
Answer
So I spilt juice on my ipod while i wasn't using it. I left it alone untill it had dried out then... (More)
Answer
my ipod nano is stuck on lock and i want the usic but it says i have to restore it because it was... (More)
Answer
My ipod skips through the menu and the volume keeps going up and down. What could be the problem and... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Apple iPod nano Second...:
Top MP3 and Digital Med... Experts
Rank: Guru Guru
Solutions: 480
Experience: By using this stuff I know what I know when I know, but sometimes don't know how I know you know??
Ask Me
Find more MP3 and Digital Med... Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
