Question about HP 358937-001 - Compaq Armada 6500 Series Laptop Keyboard (358937001KB)
Hp dv6445us notebook computer - space bar how do i get it back on?
I spilled a little bit on my keyboard so I took the spacebar off to to clean under it. Now I can't get it on. How do I get it on????
5 Suggested Answers
  • 903 Answers
SOURCE: mx3200 First the spacebar won't work andthenitworkstoowell.
did you check to make sure that the springs and bar under the spacebar are seated correclty?
Posted on Oct 25, 2008
  • 8 Answers
SOURCE: what is the little button right below the space
its turn the touchpad on an off the mouse
Posted on Mar 14, 2009
  • 10406 Answers
SOURCE: Keys qweruiop not working on startup
Take the computer to a qualified technician, who can replace the keyboard, as the least-expensive "try" at trouble-shooting.
Since a keyboard transmits "codes" to the motherboard,
e.g., left-shift-has-been-pressed, and left-shift-has-been-released,
and the motherboard interprets those codes, it is NOT likely that
the motherboard is misinterpreting the codes, especially given that
the "bad' letters are in a straight line on your keyboard.
Find an external USB keyboard, and plug it in.
If it works correctly in the first 15 minutes, then the problem is NOT the motherboard.
Posted on Jan 04, 2010
  • 1288 Answers
SOURCE: space-bar--arrow-keys-will-not-work-drink-spilled-...
in my experience, you have done all you should have to effect a repair. I would advise buying a new keyboard
Posted on Jan 26, 2011
  • 277 Answers
SOURCE: accidental spill on hp notebook
Go to ebay and look for a keyboard that fits your model, usually $10.00 to $15.00 and the search HP website on how to change your keyboard, usually four screws and disconnect a ribbon cable..
Posted on Mar 22, 2011
0 characters
1 Points
The far right and left ends of the spacebar do not work. In order to use the spacebar function, the direct middle of the button has to be pushed down.
You need to reposition (clip) the torssion bar under the spacebar key (a steel wire formed in a wide U shape), it is unhooked, call for a professionnal if you'r not sure how to do this as you may brake the plastic hinge if you don't know what you'r dooing...
Aug 09, 2011 | Toshiba 310CDT Keyboard
My dog knocked over my Compaq keyboard. Now the divided spacebar is opposite what it should be. Instead of spacing on the right spacebar I have to hit the left side. How do I fix this?
Pull the space bar off by using your fingers. Underneath, you'll find a metal rod. Take note on which way it is facing, and how it fits. Make sure nothing in broken under the space bar, then put the space bar back on making sure it hooks in correctly.
Mar 08, 2011 | Compaq Keyboard
I took my spacebar off to clean it and i dont know how to put it back on?
There is a rubber part that is designed to spring up when you release the space bar - this is the contacts that is the electrical push button. At each end the metal bar is hooked to the plastic (the long space bar key). There may be a couple springs found as well - they should seat on the base. Connect all pieces and place the space bar key over the area where it aligns to the keyboard and snap it place with a slight force.
Nov 23, 2010 | Compaq Keyboard
How do I reseat the space bar on the mx 3200 . the logitech keyboard accummulates cat hair behind the keys, easily removed. But the space bar has a spring and white gunk and does not reseat easily. Mine...
Use a credit card or plastic Id, insert it and bend it gently. If it fails, you can use 2 cards, one on each side of the spacebar.
If after all you are unable to remove the spacebar, try removing the keys around it, just remember their distribution.
Beware, the spacebar is a little more complicated to put back in place compared to the other keys, as you said, there is a spring.
Sep 04, 2009 | Keyboards & Mice
Spacebar,wont,work,after,spillin small,amount,of,juice. took.rubber,piece,off,of,my, spacebar,and,cleaned,it. but,can't,get,it,back,on. This,is,on,my,laptop
The sugar goes into the contacts and permanently deamages the keyboard. NOT REPAIRABLE. The laptop keyboards are not very expensive. You will only get that problem solved by replacing the keyboard.
Jul 20, 2009 | Logitech 967437-0403 Keyboard
The rubber plug below the spacebar button is faulty.The button needs to be removed gently and the rubber plug below it which touches the board below should be cleaned.If this does not solve the issue the rubber plug below the button needs to be replaced.Its a common problem.
thanks and please do not forget to rate the solution.keep updated.
May 19, 2009 | Dell OW7658 (J4624SK8115RT7D50) Keyboard
Keyboard spacebar sticking
Just solved it, after a bit of tinkering...
the prongs of the floating plastic frame need to sit inside the clips of the spacebar key, you can't just clip it back on with the prongs either up or down. It's fiddly, you need a paperclip or thin screwdriver to do it, but it's stopped the sticking problem.
Oct 25, 2008 | Dell OW7658 (J4624SK8115RT7D50) Keyboard
Mx3200 First the spacebar won't work andthenitworkstoowell.
Sep 30, 2008 | Logitech 967437-0403 Keyboard
I took off the spacebar and now i have trouble putting it back on to work properly
Just separate the retainer from the spacebar as good as you can and then put it in the little hooks on the left and right sides and then angle the key a little bit and snap it on. It took a while for me but I did it! :)
May 07, 2008 | Microsoft Internet PS/2 Keyboard - OEM...
Keyboards & Mice Logo
37 people viewed this question
Top HP Keyboards & Mice Experts
Brian Sullivan
Brian Sullivan
Are you a HP Keyboard and Mice Expert? Answer questions, earn points and help others
