Shredder SH2006PB
Problem for Shredder SH2006PB
Help my paper shredder is not working.
By eudarel on Jan 02, 2008
gentlemen,I have owned a DYNEX Paper Shredder Model # DX-OP1`02971 for about a year it was a gift from our kids.Lately it does not work in the on/auto position. It however works in the reverse position.Can I get this repaired or replaced by your personel without cost? I'm a seior Citizen (75 years young) on SociaLSecurity AND CAN'T AFFORD TO REPLACE IT.Can you help? Mr E.C.Bastian (eudarelcb@triton.net)
Same Problem
Jun 22, 2008
-   dynex, model no:dxop7cc. My paper shredder is stuck with paper between blades. Won't reverse or go forward but there is shredding sounds with push of buttons. Paper pulled, pushed with no movemnet of jammed paper. All loose paper removed. What can I do?. Its fairly new and not used often. -   lollymom29
Apr 26, 2008
-   I took apart the shredder and have full access to the switch. When first depressed the motor runs but only for a quick second and then stops (even though the switch is still depressed). You have to turn the unit off and on again (auto mode) to get it to work again but it's only for the one second, not continous. Any ideas?-   eloahu
Apr 18, 2008
-   Have a DYNEX paper shredder Model DX OP 102991, won't work in any mode. reverse or auto? Took apart, no apparent problem visible. Is there a fuse I am missing? When I plug it in to a known live power sorce, no sound at all, so don't think it is jammed Live in Colorado, unable to find a repair center. In the mountain areas , Snowmass Village-   Klong
Best Solution
posted on Mar 02, 2008
Helpful)
fellowesrep
Rank: Guru
Rating: 87%, 144 votes
I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad pc board, contact manufacturer for more info.
Was this helpful?
Yes
No
Popular Solutions for Shredder SH2006PB
Questions and Unsolved Problems for Shredder SH2006PB
Do you recommend Shredder SH2006PB?
Answer
Answer
shredmate-12 does not wnat to run forwrd, will run in reverse, labors and trips reset
Answer
Paper is stock in my mashine and it does'nt work, the knifes dont go around I have tried to get the... (More)
Answer
Royal 85X Paper Shredder: Runs great in Reverse. Will not start and shred in the Auto position.... (More)
Answer
Shredder will not accept paper. We already tried the small knife in the feed slot. It is no longer... (More)
Answer
need a new gear. where can I order one?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Shredder SH2006PB:
Top Shredder Experts
Rank: Guru Guru
Solutions: 769
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Shredder Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
