Question about Sony STR-DE425 Receiver
Broken power switch on Sony STR DE725
Anyone have any suggestions on how to fix a broken power switch on the STR DE725? Does Sony still sell them? This receiver still works great, but for a five cent piece of plastic that is broken.
  • JoeyDoogits Mar 14, 2008
    Same issue....switch is clearly planned obsolesence, when you take apart the receiver.
  • Anonymous Oct 04, 2008
    Another STR DE725 user with a broken power switch. Hopefully they don't make the new receivers like this...
  • 11 Answers
SOURCE: Possible blown fuse on Sony STR-DE725
Here is Sony's support site for that model.
Posted on Dec 05, 2007
SOURCE: Sony STR-K660P Intermittent sound problem
xdfcbzdf
Posted on Mar 13, 2008
SOURCE: Sony "Protection" mode - STR-DE725
My sony used to do that to umm cant remember the model but yeh i could play it at low volume but as soon as i turned it up it would start clicking and telling me to turn of the power...
I resolved it by checking every cord connected to it, it turned out that because I connected two speaker cables together i didnt seal it properly and they were touching this was making it go into protetion mode.
Posted on Jun 10, 2008
SOURCE: error 12 message on my sony multichannel av receiver str dg 510
error 12 is what you get if you autocalibrate and do not have the microphone attached.
Posted on Jan 01, 2009
SOURCE: I have a Sony STR-D565 Receiver. I bought new
I resently hooked up my sony std d 565 reciever for 5.1 speakers and I keep hearing beeping, what is wrong?
Posted on May 01, 2009
I have a Sony STR DE915 amp. It will not power up. I checked the internal fuse (it's OK). Power button has dislodged and may be broken. Am looking for disassembly instructions (not schematic diagr
Simple, if you are not confident in your ablility to fix the problem by dissasembling the boards then by all means, take it to a repair facility.
Apr 20, 2014 | Sony STR-DE915
I am thinking of buying a SONY STR DE725 (QS Series) AV receiver. I alreay have a set of home theater speakers with 5 x 80W 4 ohm and and active Sub-woofer (200W). I am wandering whether the receiver...
Yes, it will support a powered subwoofer.
If your existing speakers are from an all-in-one Home Theater in a Box and they have molded connectors you'll have to chop them off to make the ends bare wire and determine which is plus and which is minus on each. Loads of 4 ohms may present a problem at high volume levels.
Take the rated wattage of the sub and other speakers in an HTIB with a HUGE grain of salt. They plays numbers games with th low impedance and the allowable distortion levels to get the results they publish.
For all anyone knows, the speakers and their original electronics may have been designed to operate together to yield adequate performance (like Bose does). Breaking that pairing may give unpredictable results and risk of damage to the speakers or the new receiver.
Feb 18, 2010 | Sony STR-DE725
Hello, I need help with my sony str-de197 receiver. Then I hit power on button, there is a click sound inside the box, but nothing happens, there is nothing on display too. I have checked 2 fuse's, it's...
It sounds like the switch might be OK mechanically but not electrically. Have a look to see if you can check the connections on the switch. Perhaps there is a broken or loose or bad solder joint.
Oct 28, 2009 | Sony STR-DE197 Receiver
Power button broken
sony are pretty rubbish at offering patent parts, my suggestion as poor as it is would be to approach sony for this part they will recommend a retail outlet that can supply it
Jul 19, 2009 | Sony STR-DE825 Receiver
No sound out of left speaker
did the left channel work when u switched speakers, if so then the left speaker or wiring is a fault.if not then the output circuits on the amp are blown or the fuse is blown some amps have internal fuses in the output to protect the output transistors. unplug the power cord and take the cover off, look to see if u can find any fuses and check these for continuity u can hold these up to the light and u should see a fine filiment in one piece and not broken. these fuses sometimes blow just from age and use at high volume like a regular light bulb.If the fuse is blown replace with the same value else the output transistors will need to be replaced most likley along with the drivers.
May 19, 2009 | Sony STR-DE135 Receiver
No Video or Audio on HDMI on Sony STR-DG800
The sony device may not be able to support the Toshiba. Make sure that is completely compatible and that you have the correct cables and setting to support everything.
Dec 31, 2008 | Sony STR-DG800 Receiver
Battery door broken
Suggest No parts available - best bet - Gaffer Tape
Apr 07, 2008 | Olympus FE-110 Digital Camera
Nov 25, 2007 | Sony STR-DE725
Sony STR-DE425 Receiver Logo
259 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
