I was told that my convergence ic's need to be replaced along with the 6.8 ohm watt resistors. What doI ask for the ic's and what watt resistors should I ask for. where can I buy these ic's and resistors.
Comments:
Oct 28, 2009
- thank you sd tech, yes i'm pretty good with an iron and the model is a magnavox 51mp392h/17. do i get some/how many 6.8 resistors or different one's.Oct 28, 2009
- Ok sd tech, ready when you are. I'm not to computer savy so its taking me longer to get back to you. I dont know what time zone your in and dont want to make you type out a long sequence or take up to much of your time. If you would like to call my cell phone # is 704-996-3317 and you can hide your # if you'd like to, I think we'll get more accomplished this way because of my computer handycap problem. Also write back a better time for you to walk me through this or if now is a good time and if you are ok with doing this over the phone. As well I do want to repay you for your help ,i'm on a low budgit income and the tv was given to me as a hand me down so depending on how much all this stuff is going to cost to get the tv working I want to give you the left over of what i have left. THANK YOU SO MUCH, sinsearly; JR BarbayOct 28, 2009
- sd tech, thanks again. My wife always gets on my case about how much I charge people when I do construction/carpentry work as well. She's a good person and just wants me to make what other contractors make but I like to know that I helped them out more than just doing a job that any old person could do. But to get back to business here with the tv my wife said she saw that there was a better chip than the factory on, Ithink it was a 150 instead of the 120 and the add said dont cheap out it well worth it. Do you know anything like this and what exactly I should ask for? thanks for all your help and have a great night sleep. I'll look for a reply tomorrow and start on removing and checking resistors in the meen time. I still would like to send you a d&d or a starbucks gift certificate for your help Its the least I could do if I cant give you some $$. your a nice guy and your help is greatly appreciated. thanks, JR BarbayOct 28, 2009
- HEY there sd tech, It's wed. evening here on the east coast I bought some about 10 replacement resistors I asked for 6.8's but they had only two pack' one said 680-ohm 1/2 watt 5% tolerance or 68-ohm 1/2 watt 5% tolerance, I bought the 680's because they had no spot even empty spot with the 6.8 discription I hope I got the right one's. I took a picture of what I thought was the resistors you had mentioned and the respective location that they were, the discriptive # r 3149 and r 3159 were there but they are white and not the tan color that I bought. I'm confused as to whether or not I got the right resistors they start from one end to the other with colors as follows ; gold-brown-gray-blue , is there a certain order or direction that they go in with the color sequence or does it not matter. Also was wondering about the radiation there talking about on the warning lable is it just when the tv is on or pluged in ,how do you make adgustments safley from the back of the tv? I have a 15 - 30 watt solderer what watt should I use on the circutry or does it not matter? I asked my neigbor who gave us the tv if he could get me the remote and I reluctantly told him that the tv was acting strange. He said he knew there was a convergece problem after talking to someone so he changed the chips himself but said it was his first time soldering an it looked fine when he was done, but I remember my first time long ago and over the years with all my rc toys recievers and what not, so I was wondering if there was a way to tell if the chips he put in are good or not. Or do I just take a chance and replace. Then plug in and turn on and see results on screan? When a resistor is fryed does it turn white or blackish or do you think I was looking at the wrong componants and look for the same looking resistors that I got today the tan ones?
Thanks SD Tech Hope you had a great nite sleep, My wife and I are really excited to maybe get the tv to work right and truely appreciate all of your help ...Oct 29, 2009
- hey SD Tech, I realized that you had said any white or discolored resistors need to be replaced earlier. I've found r-3149 and r-3159 they are beside anouther resistor r-3149 is beside r-3150 and r-3159 is beside r-3160. There is a total of 12 from what I can see and they all look the same, kinda white or light bluish and no visable color bands, are these the resistors of concern? I will not put the ones I got today in and call around tomorrow to find the 6.8's but if these are the right location and resistor #'s let me know and i'll put them in tomorrow.
#'s 3158,3157,3150,3149,3164,3156,3151,3152,3160,3159,3153,3154.
I have got the chassis in the service position and it looks like my neighbor did an ok job but my next question is there is some flux residue around some of the pins , can this be shorting the chips or is flux non conductive? You had mensioned liquid flux, I have flux paste do I need to be useing the liquid stuff or will the paste work as well? ?Heatsink compound need more info "type" can I get it at the shack? Also grease, I have automotive grease do I need something particular? The chips, is there a noticable discoloration or way to see visaully if their bad or still good? how do I remove the heat sink from the chips without damaging anything? Please advise thanks JROct 29, 2009
- SD Tech, Are there 12 total resistors or should I only be concerned with 3149 and 3159? With the volt meter what setting do I use resistance mode "diode","200","2K","20K","200K","2M".?
Thanks we see a light at the end of the tunnel now. Of coarse I'll let you know how things go. And if you ever have any questions regarding your home or constuction please feel free to call and ask me anything, thanks so much JROct 29, 2009
- SD Tech, I put the volt meter in resistance mode on the diode setting and checked resistors it made beep sound and gave a reading of 004 I'm not sure what this meens? please advise JRNov 01, 2009
- Hey there SD Tech,
I installed the IC chips last night and installed the chassis back in this morning. Everything seems to be working great now we are getting great picture quality, but will need you to help walk us through the tech set-up when we get the remote. We will set it up manually through the volume menu for the meantime. We are so excited and hope the repair lasts for a long time, and greatly appreciate all the help and insite that you so very kindly gave us. I noticed that the SONY - CXA2089S - 409A306 computer chip factory soldering connections were touching each other so I cut a groove with a razor knife to provide seperation between the pins, also I noticed two other electronic components maybe resistors that were also making contact with each other so I seperated them as well. I'm not sure where they were located or there ID #'s But I was wondering if the SONY chip was supposed to be making pin contact, and if it sounds normal with your expertise for any componants to be making contact with one another above the normal soldering to the board?? I probably should have asked you this before I made those adjustments but figured it was strange that they were like that. Hope you had a good weekend and a happy halloween and will look out for your reply answers. Oh yeh one more thing a repair shop gave me a few sites that I might be able to get some replacment resistors in case mine fail but also they sell remotes for most tv sets but the problem is I dont know the type that goes with the tv we have and not some other model. Please advise
Thank's so much,
JR, Lauren, Leanna, and KatelynNov 09, 2009
- hey Louis66,
My name is JR and I just replaced the IC chips as recommended, it seemed to fix the problems. However we still notice some bluish hazing around white objects especially. I have tried making adjustments to the tv manualy but its still there, so I'm wondering if this might be a fluid problem? I am trying to locate a new remote so we can try seting up the tv in normal and HD, as we were told by another pro to get the best picture. Do you have any suggestions. Thanks JRNov 24, 2009
- Hi louis66,
I want to install a 12v cooling fan above the heat sinks to help keep the convergence chips from overheating. I read that this is a common problem with this tv set. I pluged a small fan into the 2 power strips for all the electronic equipment and noticed lines in the tv screen. I'm assuming that its RF interfearence. Is there something else maybe on the chassis that I can use to power the 12v fan or do I need to plug into an extension cord from anouther outlet some where else. The 12v fan is not causing lines just the small floor fan I was useing before I got the 12v fan. I would like to connect to a 12v part on the chassis so I dont have to keep sliding the tv out to unpluge it when we are done watching tv, and to have it turn on when we turn the tv on. Can this be done? and can you advise me on where to tap into on the chassis.
THANK YOU, JR
