Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Unable to watch DVD's on this TV
I have connected my DVD player the TV exactly as described in the instruction manual but no matter what, I get all these green lines and scattered green bits all over the screen. The only thing I have been able to watch is either my Direct TV receiver or HD cable box that are plugged into the AV4 jacks. Anything else, VCR, DVD player, plugged into AV1, AV2, AV3 gives me those green lines and dots. Being an HDTV monitor, I'm sure that has something to do with it but what can I do?
    Problem Solver:
  • 14 Answers
Your DVD player may be set up to put out a different mode. Are you using the component cables or s-video? If it's the component cables, make sure you're player is putting out 480p. Also, try it with another set to see of you can localize the problem.
Posted on Jan 14, 2008
Connecting JVC HR-XVC27U VCR/DVD Combo to DIRECT TV
Here is a link to a line diagram to connect most tv/dvd/vcr/direct tv.
Apr 22, 2008 | JVC HR-XVC27U DVD Player/VCR
Hi i have an alba tv , im trying to connect a dvd player. I have connected the scart leads etc.I can not get onto the av channel so i can watch a dvd. Please help
Firstly, please make sure you have connected the SCART cable correctly. This should be connected to a SCART OUT socket on the DVD player to one of the SCART IN or EXT sockets on the rear of the TV.
If you have correctly connected the SCART cable the TV should automatically switch to the AV channel when you switch the DVD player power on or insert a disc.
Switch your TV on, then switch the DVD player off and then on again. If the TV does not change to the AV channel you may have the SCART cable connected incorrectly.
Not all TVs automatically switch to the AV channel when the AV device is switched on. On some TVs the AV input is on channel 0 or 99. On other TVs the AV input is not assigned to a specific channel. On these TVs you need to look for a button marked "AV", "INPUT" or "SOURCE" - either on the TV remote or on the buttons on the front of the TV. The easiest way to do this is to insert a disk into the DVD player and start it playing. Then press the "AV" "INPUT" or "SOURCE" button (whichever one you have) repeatedly until you find the signal from the DVD player.
Please check your connections and try using the "AV" "INPUT" or "SOURCE" buttons. If you are still unable to watch your DVD player, please post back with the following information:
1. Model number of the Bush TV
2. Brand and model number of the DVD player
3. If you are using any remote other than the ones supplied with the TV or DVD player, the brand and model number of the remote.
I will then be able to tell you exactly how it should be connected and which buttons (if any) you need to press to access the AV channel.
Hope this helps. Happy New Year!
Regards,
BElectric
Jan 01, 2011 | Televison & Video
Cannot record without watching the programme
This unit does not have twin tuner,you would have to watch another channel on the tv.
Dec 03, 2009 | Panasonic Televison & Video
I need instructions on how to clean the lens on a Panasonic DVD Recorder Model # DMR-EZ17. he manual says to use the DVD lens cleaner. We bought the unit two years ago and I don't know what the lens...
Radio Shack ($13)
The lens cleaner is a CD "Audio" disc that has some imbedded brushes on one of the audio tracks.
Read the instructions carefully (no harm if it's not done right). Turn ON your speakers or listen to the CD/Cleaner through your headphones. There are no chemicals involved, and can be used several times.
The problem (darkness) may not go away.
It seems more like the voltage level on the DVD output or the TV input is too low.
If you have several things connected to the DVD, disconnect them, except the TV.
If you have other devices turned on that are connected to the TV, turn them OFF (like a VCR or another DVD player, etc).
Please "comment" back...
Hope this helps!
Sep 08, 2009 | Televison & Video
Can I watch tv with the timer on the dvd recorder turned on?
Hook up the cable wire that comes directly from the wall to the dvd recorder's in connection, then get a 3 ft cable cord and connect from the out of the dvd recorder to the in on the tv. You should be able to set the dvd recorder channel and timer and leave it off. you then should be able to have your tv on and watch any station but to watch the tv with dvd recorder on, your tv should be set to either channel 3 or 4 depending on the switch on back of dvd recorder. I hope this solves your problem. Foxpaw13
Jun 15, 2009 | Panasonic DMR-EZ37VS
Unable to install correctly - hd tv ok - dvd wont install
what type of cables are you using? are you using the HDMI cable that comes with the unit? your tv also has to be HD compatitable.
Dec 19, 2008 | Philips DVDR520H DVD Player/HDD
Hooking up GPX D1816
it really doesnt matter what color the cables are as long as the one from video out on the dvd player is going to video in on the tv then the same for the sound.yellow is generally video and red would be your sound
Aug 03, 2008 | GPX D1816 DVD Player
Trying to connect dvd player
You will have to connect your DVD player to the plasma TV, not the cable box. The cable box (or most cable boxes) have video outputs only. The same is true for the DVD player: it outputs the video to the tv.
Look in your DVD manual for scenarios for connecting your player to the tv.
Mike
Dec 06, 2007 | Panasonic DVD-S27 DVD Player
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
