Is the switch on the hood for brush speed set to full, or may it be set to OFF?
Remove the brush block from under the unit by pulling it down and unlatch each side. Is there a 1/4 inch square drive pin on one brush, about two inches long? It connects the brush to the drive mechanism.
Lastly, the drive mechanism in the base may be bound-up, and not spinning. If so, the unit needs disassembled to repair or replace.
when I use it it leaks out of bottom. when it off an water in tank leaks out of bottom,when its off...
(More)
when I use it it leaks out of bottom. when it off an water in tank leaks out of bottom,when its off an I pull the triggar it flows big time out of bottom. tank doesnt leak when off sitting with water in it
can't find a user manual for a commital sami TR5 steam cleaner. Made in Italy. Cannot put product in...
(More)
can't find a user manual for a commital sami TR5 steam cleaner. Made in Italy. Cannot put product in the product window
