You'll probably get 480p if you use a cable box using the RGB outputs from that and plugging them into your RGB component input on the jack panel . You won't get 720p on that set, but you'll wind up with a clearer picture than regular RF. So, your answer is no, you won't won't get it without a box if your using an air signal.
You do need a separate HD Receiver, HD Satellite, and or HD Cable Box to receive HD. It only has a Standard NTSC Tuner built in.
I hope this helps,
Sky Assoc
I have a Hitachi model 60v500a. I first replace the lamp of the tv and now the middle of the screen...
(More)
I have a Hitachi model 60v500a. I first replace the lamp of the tv and now the middle of the screen is a little yellowish and foggy. What could it be now?
My Hitachi Ultravision 60V500A tv's bulb just died. I was wondering how much it is to replace, and...
(More)
My Hitachi Ultravision 60V500A tv's bulb just died. I was wondering how much it is to replace, and can I replace it myself? or do I have to get someone to come do it?
I have a Hitachi 60" rear projection lcd tv model 60v500a. The screen has a red area in the...
(More)
I have a Hitachi 60" rear projection lcd tv model 60v500a. The screen has a red area in the middle of the screen and any picture with red is blurry. What needs fixed?
