Acer Aspire L100 PC Desktop
Problem for Acer Aspire L100 PC Desktop
No power when press the button, power plug is
By totalcontl on Oct 28, 2009
No power when press the button, power plug is good?
Solution #1
posted on Nov 26, 2009
Not Rated)
Starworx
Rank: Apprentice
Rating: 0%, 0 votes
Acer L100 doesn`t work with Molex power connectors. Its a standard laptop supply. It is possible that your mainboard os defective. Acer L100 and AcerPower 1000 series have a lot of overheating problems. I have seen failure rates of 80% ....
Was this helpful?
Yes
No
Solution #2
posted on Oct 28, 2009
Not Rated)
cyberdyers
Rank: Guru
Rating: 86%, 160 votes
Good day sir/ma'am, chances are that your power supply box is the faulty part. But to make sure let us test your power supply box. here are the steps:
  1. PC is off, open the side panels of the CPU, disconnect the 20(or 24) pin molex connector from the motherboard.
  2. Get a piece of jumper wire, about 4 inches and splice the ends.
  3. On the molex connector, locate the green wire, then using the jumper wire, short it with the black wire (there are lots of black wires there).
  4. look at the exhaust fan, at this point it should be spinning (good). if not here are the other possible outcome: (1) the fan did not spin. replace the power supply box with a new one. (2) the fan spins momentarily then stops, this condition only occur once. Its either your power supply has no load (intermittent symptoms), or the switching controller stage part is faulty. Better buy a new one than have a headache. (3) blows a fuse. replace the entire box.
If you have a good power supply, install it on your CPU and test.
Was this helpful?
Yes
No
Popular Solutions for Acer Aspire L100 PC Desktop
Questions and Unsolved Problems for Acer Aspire L100 PC Desktop
Do you recommend Acer Aspire L100 PC Desktop?
Answer
Answer
i cant get my e169 modem to work on a eeepc 701sd
Answer
Need to separate main case to repair DC socket. Cannot find last screws? around socket. Seems 2... (More)
Answer
Yesterday and today I can not access my yahoo mail (ctrl-alt-del shows ''not responding''). I have... (More)
Answer
Back at the end of Sept, you posted: "I have a solution for L100 heat problem. My idling temps... (More)
Answer
Where can I get a replacement antenna for an Acer L100. I lost mine after my move to college, and... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Desktop Experts
Top Computer & Laptop Repairmen
in , FL
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
