Home | Hoover | SteamVac Carpet/Upholstery Deep Cleaner Vac... | MY HOOVER DUAL V STE...
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Problem for Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
MY HOOVER DUAL V STEAM VAC CARPET CLEANER BRUSHES
By brandibev on Oct 28, 2009
MY HOOVER DUAL V STEAM VAC CARPET CLEANER BRUSHES WILL NOT SPIN! WHY?
Best Solution
posted on Oct 31, 2009
Very Helpful)
rkintz
Rank: Wiz  Vacuums  Expert
Rating: 82%, 55 votes
There are three things to check:
Is the switch on the hood for brush speed set to full, or may it be set to OFF?
Remove the brush block from under the unit by pulling it down and unlatch each side. Is there a 1/4 inch square drive pin on one brush, about two inches long? It connects the brush to the drive mechanism.
Lastly, the drive mechanism in the base may be bound-up, and not spinning. If so, the unit needs disassembled to repair or replaced.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Hoover SteamVac
Questions and Unsolved Problems for Hoover SteamVac
Do you recommend Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum?
Answer
Answer
Brushes on Hoover Steam Vac F7441-980 do not turn.Brush control on;drive pin present;filter intake... (More)
Answer
the upholstery attachment won't slide down to meet the opening for suction. Don't know how to attach... (More)
Answer
How do I take it apart to clean it - hover model f6213-900
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hoover SteamVac...:
Top Vacuum Experts
Rank: Guru Guru
Solutions: 881
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Vacuum Experts
Top Vacuum Repair
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
