Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
FIXED! 1 DOWN 4 TO GO...
I just wanted to post that I was able to purchase the IC units and tested all resistors on this Philips TV and fixed 1 of 5 that we found in a storage unit.
The convergence was the problem and I was able to carefully label each wire and connector before removing the board. Then after I removed the board (finally) I desoldered the ICs, removed them, and soldered the new ones in. I tested the resitors and they tested at .4ohms each, they were fine.
Reconnected and reinstalled board. Tested all lines with a VCR, instant success, converged on it's own. Doing another one tommarow, wish me luck!
  • dvsax Jan 02, 2008
    Today I worked on two more of these TVs. Replaced the ICs on both and they each needed 2 resistors. The resistors turn brown when they go out. But I tested each one. The first TV worked perfectly after the fix. However the second one still has a fuzzy red outline around white and warm colors. I need a solution to this problem now. Of the five so far, I've fixed 2, semi-fixed 1. and havent started the last 2.
  • dvsax Jan 10, 2008
    Ok I have replaced all the resistors and ICs in the 5 TVs.
    1 has a yellow tinted area in the middle of the screen. Need help here.
    2 have FUZZY red and/or blue convergence crosshairs. ICs & Res. are new SO I need help here.
Replace the coolant in the len's!!!
Posted on Jan 07, 2008
6ya staff
SOURCE:
The problem I am having is that when I turn on our tv vcr/dvd combo unit, it only wants to stay on for a few seconds and then it shuts off.
I have fixed one of these combos before. The problem seem to always been the zener diode to regulate power. It developes a leak which would cause increased voltage, and goes into shutdown mode.
Jun 28, 2009 | Philips Magnavox 27MS343S 27" TV
Philips magnavox 60" rear projection no sound no picture
That could be from
1) Faulty Lamp
2) Vertical/Horizontal Output IC
3) A Shorted IC driver
4) Blown fuse
5) Open resistors around the fuse
Keep all of these in mind and I would test the IC's first with a multimeter,IC's are transistors,usually having 3 legs and screwed into a heat sink,if they read 0 they are shorted. Also if you find something has gone bad,look around the component to see if there is an underlying problem as it will be frustrating and more expensive to find out after the first replacement.
May 11, 2009 | Philips Magnavox 9P6034C 60" Rear...
Detailed problem per your response
The problem is that the ICs may have been blown because the resistors were bad. Just as a double check before you replace anything else. Please confirm that the STKs are STK392-110. Also, replaceing them with STK392-150 is a valid upgrade, I'm not sure about the 180s, but I'll check. Both the STKs and the resistors need to be changed at the same time.
The hour glass view you reported: Was the bowing on the top and bottom or on the sides?
Thanks,
Dan
Sep 11, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Red Offset Image
yes the convergence ICs need to be replaced they are both STK392-120 ICs and you will also need four 6.8 ohm 1 watt resistors you can get replacment ICs and resistors at the following link and they provide free instalation instructions with pictures and free on line instant messageing to help you do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
Aug 14, 2008 | Philips 55PW9363 55" Rear Projection...
60pp9352 convergence ic replaced multi points corrected but image squeezed
one of the resistors must be open, you cant always tell by looking if theyre open you have to remove one leg out of circuit then test them for resistance they can only be 5% out of tolerance, any more than that and they must be replaced.
Mar 27, 2008 | Philips 60PP9352 60" Rear Projection...
Phillips 32PT6441/37 32 Inch Screen / Power problem
I fixed this very problem several times on this set. You must check some parts and, if bad, replace them correctly and safely. I can tell you what to look for for a small cash fee, but I don't know how this works on this site.
Jan 27, 2008 | Philips 32PT6441/37 32" TV
TV PROBLEM
Resoldering all the pins on the flyback transformer will fix this. Common problem.
Sep 08, 2007 | Disney DTD1363-CAR 13" TV/DVD
Phillips 60PP920217F Convergence Problems
replace ic chips pt# stk392-120 or stk392- 150 and there are 12 resistors located near ic clips pt# 6r8 ( color code blue - gray - gold - gold ) board location no#s 3149 thu 3160 if you look close you may find two resistors discolored as i found on my convergence circut board , also use heat sink compound on new ic chips , take your time to mark all wire connectors going to board from tv , also use .022 dia gage rosin -core solder and a 15- 25 watt soldering iron you may have to adjust the red - blue convergence afterwards my tv set is 3 yrs old also ( thanks holbert )
May 03, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
48 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
