Question about Whirlpool GS475LEKS Gas Kitchen Range
Oven Door How do you reinstall the oven door?  I pulled mine off when pulling out the stove for a gas flex-line repair.
Yes it did lift off in upward pulling. Can't get the oven door back on...Need help?
Posted on Sep 20, 2008
  • 869 Answers
Did it lift off in upward pulling>?
Posted on Jun 01, 2008
6ya staff
SOURCE:
How to remove a Maytag gas stove oven door (Maytag Model # MGR5755Qwd)
Hi.
Before removing the door you need to release the lock on the oven door hinges. Door hinge locks are slide mechanisms or pins located on top of the hinges Once lock is released you will be able to pull out the door by opening it a bit, then lifting it up and pulling out.
Here parts and diagrams for your oven: MGR5755QDW.
Regards.
Ginko
Sep 09, 2011 | Maytag MGR5755QD CleanDesign Gas Kitchen...
Apparently a spring on my oven door is broken (DCS-RG-4844GG). On the large oven door, the left hinge has no tension in it. I can latch the hinge to remove the oven door for cleaning. However, when I...
spring is broken on the side that is 'slacked' without return tension. may be necessary to get underneath the stove chassis. move away from wall, carefully disconnect the gas fitting after turning off the gas spigot. Pull away far enough from wall to 'tilt' the whole chassis rearward to access the underside. Technicians use a 'jack' to raise stove....
Dec 02, 2017 | DCS RGS-484GG Gas Kitchen Range
I have a frigidaire GAS stove. Oven doesn't work.
Even though the ignitor glows it does not mean that it is working...sounds crazy but it is true... the ignitor needs to pull a certain amperage to let the gas valve open and as they get older they stop pulling enough current...
Check out this tip I wrote about this problem...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Heatman101
Mar 04, 2010 | Frigidaire FGF316 Gas Kitchen Range
Hotpoint gas oven 5yrs old pre heats fine but then doesn't keep temp up.
You have either a faulty oven thermostat, or your oven door seal is faulty. You can check the oven door seal by doing the following (you will need a A4 piece of paper):
Open the door put the paper against the seal, close the door. Now pull the paper slowly out, if there is resistance then the seal is fine.
The oven thermostat test is as follows (you will need a stopwatch):
Turn your oven on to the lowest setting,when it goes to high flame start timing it the oven should cut down within 8 minutes, if this doesn't occur your stat is faulty.
I hope this helps
Jul 06, 2009 | Frigidaire Gallery 30" Self-Cleaning...
Oven door hinge detached from the oven
Pull the door completely off and re-insert the door on the hinge supports.
May 23, 2009 | GE Ovens
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
GE Profile Gas Range oven light doesn't work even after changing
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
How to install Maytag oven door for model MGR5765QDQ ?
Pull the door mount bars to the first stop--where you keep the door open to broil. Slide the door back down on the bars.
Mar 02, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
My oven door came off and I can't get it back on
I have spilt milk flowing down the side fo oven/counter top and needed to pull out the stove to quickly get it wiped up..I pulled the stove out by the oven door handle. The hinge sprang on the right side and the oven door is now off on one side how to get it back on?? My husband lifted the door up and the whole door is now off.
It is very difficult to replace, what are we doing wrong???!!! Please help. I belive it is a whirlpool electronic model. thankyou.
Jan 08, 2009 | Jenn-Air JER8850 Electric Kitchen Range
Stove handle/door
need strong fingers and a helper... lay the door on the floor push open the hinges and there is a hole on the side of the hinge have your helper slide in a small nail only about 1/4 " in to the hole this will keep the hinge out do the same on the other side then reinstall the door open up and remove your nails
Feb 26, 2008 | Whirlpool RF315 Dual Fuel (Electric and...
Whirlpool GS475LEKS Gas Kitchen Range Logo
182 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Archie Ferrarini
Archie Ferrarini
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
