Question about Durabrand HT-3915 System
Output problem My system has been working flawlessly for quite some time, but suddenly it stopped working. Power comes on, but when I try to play something, the speakers make clicking sounds. Not sure how to fix this.
  • ray-dog Feb 09, 2008
    i recently bought my sys. and set it up on my home computer,worked well
    the first month.then it started to make a clicking nose and the volume would change,now i get no sound out of the speakers at all. in looking into the problem i found that the audio in jack on the sub speaker was loose
    inside the speaker box in turn the plug was not making a good connection.
    i can move the plug around and i can get to work but i have to hold it in that position. this sub. is a sealed unit.guess i'll have to try to get the co. to replace it
  • 56 Answers
First check all the cables that there is no bad connection.If this doesn't solve the problem your amp is worn out
Posted on Mar 10, 2008
Sony Mini Hi-Fi Systwm shuts down at high volumes
You need to have the fan in the check,possibly its not working anylonger
Jan 22, 2014 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Hey I've had my Logitech z506 speakers for a few
I don't know for certain but, this is usually a sign of the overload circuit in operation. Speakers are not designed to be used on full volume constantly. Next time this happens try and turn them off for a couple of minutes, when you turn them on again try with the volume lower than when you turned them off. If you are regularly using them at full volume, then maybe it is time to invest in a more powerful set. Buy them by their RMS power output, NOT by their PMPO (peak mean power output) this is already an inflated figure and is usually about 4 times the real power output. I hope this helps.
Jan 21, 2013 | Audio Players & Recorders
My Bose lifestyle amplifier (SA-2, SA-3) suddenly stopped working while playing stored music. It has worked flawlessly for over 3 years until now. I replaced the batteries in the remote and checked all...
Check your settings on the main system setup mode and make sure the amp is enabled. If you still have an issue, post a comment and I can help you further.
May 30, 2011 | Audio Players & Recorders
I have a 2 month old Honda Eu2000I generator that until today has performed flawlessly. The ac output suddenly stopped though the output light continued to glow green and the engine continued to run. The...
Try checking the output with another appliance, the shop vac may have over heated (for whatever reason). The generator, if it encounters one, has a fault light (if memory serves) that is illuminated if anything out of the ordinary is encountered.
Feb 13, 2011 | Honda Electrical Supplies
My rear and center speakers suddenly quit working. No sound
try a different source. if there is output on all speakers in test mode, then the amps are good but the source or source switching may have a problem.
Mar 01, 2010 | Audio Players & Recorders
Suddenly, amplifier stopped giving out sound. Controls and display seem to work fine. If it is blown fuse, where is it & how can i replace it?
Does it stop on both channels? It sounds to me like the safety circuit is activating. This usually happens when either the volume is too high, or the speaker load is too great (i.e. usually loads less than 4 ohms will do this) or, the amplifier has an internal short causing the amplifier's output stage to become un-balanced. Does the sound come out nice and clearly through both channels? How long does the receiver play before the sound stops? How loud are you playing the music when it stops like this? If the sound is reasonably clear through both channels at regular volume, then there is probably nothing at all wrong with the receiver's output circuits. If the amplifier is being played at regular volume or even lower volume for quite a while and then quits, perhaps the receiver is getting too hot and it's thermal sensors are activating the protection circuit. Make sure that when you operate the receiver, that there aren't things laying on top of it blocking the unit from venting and cooling properly. Make sure it has plenty of breathing room - amplifiers (most of them anyway) are inherently subject to producing heat. If the amplifier only quits when played at high volume, well then that's probably the problem - it's probably not meant to deliver such power that you're asking it to - especially if you're driving a heavy load such as 4 ohms or less. If you're running several speakers on this unit, try scaling back to just two speakers for now, and make sure these are 8 ohm speakers. Play the unit for a while and see how it does.
Oct 24, 2009 | Aiwa AV-DV95 Receiver
"Push Power'' and ''Protector"
my sony bravia is KLV-32S400A. i tried to stop the dvd playing and turn off the home theatre, but the tv is still on. suddenly there was a loud blast sound and the home theatre shows PUSH POWER PROTECTOR.
please help what should i do with it?
May 13, 2009 | Sony DAV-HDX500 System
Soundmax Hd audio not working.
SOUND LIKE THE CHIP SET IS BAD.
overheat??? or a bad solder joint. but either way it is related to heat.
try a can of cold spray, spray very small area at a time when the sound die. once you id the area then you can nerrow down by spray in a even smaller area. till you fine the part..
good luck
Nov 17, 2008 | Computers & Internet
Power Problem? My DS55 red standby light blinks at me and won't turn on.
I agree with your diagnosis. If one channel quit and the unit now ocassionally won't output at all then the amp is going into protect. Have it serviced.
Sep 20, 2007 | Aiwa NSX-DS55 CD Shelf System
Iriver h320 dead headphone output jacks
Tried new set of head phones? My DAD fixed cars and always said to fix the cheapest part that might be haywire first.
Jul 24, 2007 | iRiver H320 MP3 Player
Durabrand HT-3915 System Logo
90 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
