Question about Toshiba Satellite A70 Notebook
Shutting down/ and has a partition fault
Hi I have had this since 04, the computer starting shutting itself down for no apparent reason, I put it in to get it looked at but the repairer said it never shut itself down when with them, so took it home plugged it in and it started shutting down staight away, I was then told to put in the recovery disk, which I did now it starts going through the process and shuts down whilst still in the process. now when you turn it on it comes up with a partition fault, with no dos promp
  • 239 Answers
There a link to a Dos program if you have a cd burner you can do this if what I try to tell you to do does not work first. Ok can you get into bios, if so try and go into the boot sequence and make your Cd/Dvd rom No.1 and you HDD No. 2 leave the rest as they are, Ok now save your setting and exit you bios, Now put in your operating system Cd and boot from Cd, Now you can do a R repair or and you won't loose all your files music ect..
Or you can do a total fresh copy of windows on your computer. See if that gets you up and working, If not go to the link above and burn or save Dos files and install them on your computer and once you do that you should be able to install you system back to normal, Also make sure you are not plugging the vents on the sides or underside of the computer overheating will cause it to shut off, a fan blowing on it could also help. sounds like its overheating to me so try and keep it cool while doing what you have to do, I sure hopes it help you out, If It does not write back here and let me know what else is up and we will see if there is another solution for ya. Take Care Bear001.
Posted on Jan 02, 2008
My computer continues to shut-down for no apparent reason while booting up. It will get to bios then abruptly shutdown. Please Help!!
Maybe something is defective from the factory? Can you bring it back and exchange it for another? Is it a desktop or a laptop? If it's a desktop, maybe remove a side panel and aim a small fan at the inside. Do you know how to start up your computer in safe mode? Maybe try starting it in safe mode and see if you can do a system restore, do you know what that is and how to do it? Google will explain it to you, but I'd suggest those steps.
Mar 21, 2017 | Gateway Fx Computers & Internet
Shuts down
This is a typical symptom of a failing power supply. Replace your power supply and see if the problem still persists.
Please notify me should you need any further assistance.
Best wishes,
Jan 06, 2012 | Intel DP55KG Motherboard
Computer keeps shutting off every five minutes or so
Computer may be shutting od due to following reasons:
Computer Virus
There are higher chances of a computer shutting down due to the interference of a computer virus. The virus gets into the computer and fiddles with crucial sections of the operating system, which may cause the system to shut down automatically. You need to install a good antivirus software and get the computer scanned thoroughly for any malware and viruses. Also see to it that the operating system and all hardware drivers are updated.
Power Supply
The computer power supply unit is an equipment that is installed in the cabinet to provide power to the system for operation. Your computer can shut down, if there is not enough power supplied to it for handling the programs running. If you are using the computer for running intensive software such as PC games, the system would require more power than what is actually available. Another reason can be overheating of the power supply. After the power supply is used for a substantial period of time, there is a possibility of dust getting collected inside it. And this may cause it to overheat, resulting in the shutdown of the desktop computer. If the power supply is at fault, you may need to get a new one installed.
Overheating of the Motherboard and the Processor
As with the case of dust getting collected in the power supply, the computer motherboard and the processor can also collect dust, which may be the reason for their overheating. This may also be one of the reasons why your computer keeps shutting down and restarting. You need to open the computer cabinet and clean the dust off the computer parts. The CPU board and the processor can also overheat because of many applications running. If this is the case, then it is suggested to keep the running of applications as less as possible or increase the size of Random Access Memory (RAM). Bad capacitors on the motherboard is also one of the reasons, why your computer keeps shutting down very often.
The 'Automatically Restart' Setting
If you are using Windows XP operating system, there is a setting that indicates the computer to reboot if it detects an error in the system's operation. In order to check if this is the problem, click on 'Start' and 'Control Panel', then select 'Performance and Maintenance'. Click on 'System', then the 'Advanced' option, and select 'Settings' from the 'Startup and Recovery' section. You will find an 'Automatically restart' option, which you need to uncheck for preventing the system from rebooting. Read more on computer keeps restarting on its own.
These were the possible reasons, why your computer keeps shutting down and rebooting. You also need to check if the power cables are properly connected to the cabinet and to the UPS, as loose connections can also be a reason for system shutdown. The most common cause of the computer getting shut down or restarted is due to overheating of the power supply and other internal computer parts.
Dec 29, 2010 | Mirus Computers & Internet
I have a hp pavilion ze5170 laptop and it is shutting itself off for no apparent reason. anyone know what could be causing this? it doesnt appear to be software related. its not crashing just turning off.
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Aug 28, 2010 | HP Pavilion ze5170 Notebook
My computer keeps shutting down for no apparent reason... I hasve a toshiba satellite p10...
Possible causes of the problem:
System overheating
- Virus infection
- Power supply malfunctioning
- Check your computer if the fan is properly working.
- Scan your computer for viruses
- Check your computer power supply by a qualified technician
- Reinstall your computer operating system
Try this also:
From the run box you can type shutdown -a and that should stop it from shutting down long enough for you to fix the problem.You need to look up how to remove msblast from your computer.
Nov 17, 2009 | Toshiba Satellite P105-S921 Notebook
Formatting problem
Put your hard drive as a slave on another system and delete the desire partition with hard disk tool called Partition Magic or Power Quest. It is Microsoft utility.
This will solve your problem. I am doing same thing when I got problem in any hard drive. It is powerful tool.
Oct 31, 2008 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
04 grand prix shuts off
My 04 Grand Prix was doing the same thing. Not sure if what I found was the reason for it, but I removed the air filter portion of the intake, reached into the intake a little pulling the throttle plate down. It was caked in carbon build up. With a lint free rag and some throttle body cleaner, I scrubbed the plate and since have not had anymore issues with the car not starting. Hope this helps anyone.
Oct 06, 2008 | 2004 Pontiac Grand Prix
Computer shutting down randomly in the middle of everything...even offline games
This can be the result of a virus infection or an infection of other malicious software such as spyware.
Run a thorough system scan.
If this doesn;t help, tell me and we'll go to the next thing to check/do for this kind of problem.
Jan 25, 2008 | Microsoft Windows Vista Ultimate Edition
Treo 650 keeps shutting itself down
Hi muchlove,
Please backup your palm to memory card using palm backup application or hotsync it to your computer, then you do a zero-reset. Here's the step by step how to zero-reset:
If this solve the problem than it caused by software conflict. Please let me know the result.
Nov 02, 2007 | Palm Treo 650 Handheld
Dehumidifier keeps shutting itself off.
For some reason it is overheating and shutting itself off. There is a law that all electronics are supposed to have a point to where it automatically shuts off if it gets too hot from a malfunction or loose connection in the circuit board. It is to protect the consumer. You either need to take it to a tech or get rid of it. Get a new one.
Sep 13, 2006 | GE AHG40LA Dehumidifier
Toshiba Satellite A70 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
