-   Card unlocked in a matter of seconds....Thank you so much! I thought I was going to have to buy a new card...this one cost me 60.00! Thank God for the internet....this wasnt covered in the manuel -   Guest
Apr 27, 2009
-   o my god i love you this worked perfectly and i needed my camera rite away for a event and thought i wouldnt hav one for tomarrow but thanks to you noe i do -   j-zthecutie
Feb 08, 2009
-   wow how easy! thanks for your help!!!-   Guest
Jan 14, 2009
-   I looked inside the slot where the card goes and down on one side is a button/switch which appears to have gotten stuck ,i took a paperclip a moved it, no longer reads locked, it was that tiny switch although if it happens again i will take a small drop 3 in one oil to it
-   lafly
Jan 11, 2009
-   my camara ( HP photosmart E427)gives me the message : 'card locked' how can I unlock it-   Guest
This just happened to my camera and I was sure after reading the other posts that it was about time to by another camera. After going trough three completely new and unlocked cards i switched the card to the lock position and placed it in the camera. Sure enough it still said locked, but I then removed the same card and pushed the switch to the open position and reinserted the card. The error cleared and now my camera works fine. This worked for me hopefully it will work for you. I have a feeling that the camera just needed to be reset and that trick worked for me. Good luck!
Was this helpful?
Yes
No
5 people thought this was helpful
Solution #3
posted on Apr 18, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Thanks. Perfect. It doesn't say anything about this problem in the owner's manual. I didn't know you could adjust something on the card itself
I have a Traveler DV-5040 and have installed the driver for Windows.Hoiwever I need some...
(More)
I have a Traveler DV-5040 and have installed the driver for Windows.Hoiwever I need some simple,basic instructions in detail as to how to download my images as the manual is not specific in this regard. Thank you
why my camera the power is not on?? i connect it to my laptop but nothing happen..and even i turn it...
(More)
why my camera the power is not on?? i connect it to my laptop but nothing happen..and even i turn it on with the battery..it still wont on..can you help me please
GOT THE ANSWER FOR THE LOCKED CARD. THERE IS A SLIGHT BUTTON ON THE SIDE OF THE SIM CARD THAT SLIDED UP AND DOWN. SLIDE IT TO THE OTHER SIDE... AND WHA-LAH.. UNLOCKED.
My son turned on his FP tough camera and it won't allow him to take pictures. It is showing the camera is locked. What can we do?
Comment by Guest, posted on Nov 26, 2008
Camera worked good for 2 years until I pulled the card and deleted the files to insure I had enough space.Now I get Card Locked. I am still earching but if all else fails I will send it back for service.
Comment by Guest, posted on Nov 02, 2008
We have the same problem. Suddenly showed card locked. I took the camera back to London Drugs and they are sending it in for servicing. They think it may be an internal problem. They said it was for sure not a problem with the card. Will have to wait about 3 weeks to get it back.
I've now bought two SD memory cards for my Canon PowerShot SD630, one 2GB and one 4 GB (different brands) and am getting the "Locked" error on both, although I've toggled the "Lock" switch both ways. Very frustrating, since the card that shipped with the camera holds 8 photos. I'm not seeing any solutions here.
Valerie
Even if I switch the lock button on the card it does not change. Everytime I want to record something on the card it says card locked. But the card works perfectly in other cameras.
Comment by Guest, posted on Sep 30, 2008
yes i have same problem i have changed even new card
